Blower motor issues
Blower motor issues
Alright, having issues with the blower motor, or the heater box, not sure which.
So when I have the heat on in my truck, on Vent, driving down the road it will occasionally switch over to Defrost on it's own. Then it will eventually switch back to Vent, and so on. Also what it is doing is now when I have the air turned OFF, it is blowing air on the Floor, and Defrost at the same time. Was wondering why it was staying warm in my truck with the air off!
So any ideas what is going on here?
One of them vacuum lines (not the one in the picture but the one that goes to the vent selector valve from the engine intake manifold) has a check valve in it. If that valve is missing or the line's split/crumbling where it connects to the valve (and especially if you've also ditched the vacuum accumulator) then when you give it much more than half throttle you'll dump all the vacuum from the vent controls and end up in defrost.
You can rent a hand vacuum pump at most auto parts stores and then get your money back when you bring it back.
danielcoyle
25
11-03-2014 05:43 AM
Ooghammer
10-07-2014 09:04 AM
joshhaywood
1983 - 2012 Ranger & B-Series
01-23-2006 06:32 PM
sg
11-02-2000 08:44 AM
