Go Back   Ford Truck Enthusiasts Forums > Misc. > Aftermarket Products
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Aftermarket Products SPONSORED BY:
  #1 (permalink)
Old 10-17-2012, 08:17 PM
Power of 8's Avatar
Power of 8 Power of 8 is offline
1991 Ford F-250
Power of 8 is starting off with a positive reputation.
Computer controlled cams?
I have a 1991 F250 4x4 EFI 351w V8 with hooker shorty headers, true dual exhaust with 3 inch stainless steel piping with flowmaster super 44s.
I've been looking at hydro rollers and I need to know if "computer controlled" is important because almost every one I look at isn't "computer controlled compatible".
Thanks.
  #2 (permalink)
Old 10-20-2012, 10:25 AM
Conanski's Avatar
Conanski Conanski is offline
1990 Ford F-150
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Quote:
Dual 3" all the way back? That's too much exhaust for a 460 so you're losing quite a bit of low end torque.
Rockers or camshafts? If it's rockers you're talking about that rating doesn't apply.
That truck has the SD EFI system on it which means if you you're changing the cam it has to be compatible with that system or "computer controlled", in general that means no less than 114 degrees LSA and no more than 210 deg duration at 0.050" lift. However you will find some cams that meet those specs(or are very close) that aren't rated computer controlled so there are a few more options available. Your motor currently has a flat tappet cam in it as well and converting to a roller involves using linkbar roller lifters and shorter pushrods which drives up the price quite a bit, but considering how many flat tappet cam failures we're beginning to see it's probably worth the expense.
__________________
Paul (Conan) O'Brien
1990 5.0HO AOD XLT X-Cab F150 3.55LS, 1990 2.3L 5-sp Ranger 3.08, 2004 3.0L 5-sp X-cab Ranger Edge 4.10, 2004 2.5L 5-spd Subaru Legacy
1996 Kawasaki ZX11D, 2004 Honda 599, 2008 Kawasaki KLR650
  #3 (permalink)
Old 10-20-2012, 12:05 PM
Power of 8's Avatar
1991 Ford F-250
It's a 351w not the big block 460.
So it doesent matter what it says as long as I change the rockers and lifters? Or are you saying that I have to go into the computer and change stuff in order to get a bigger cam?
  #4 (permalink)
Old 10-20-2012, 04:05 PM
Conanski's Avatar
1990 Ford F-150
Yes exactly.. so you have 2 times too much exhaust for that motor, even a single 3" is overkill.
Neither of those, what I'm saying is it doesn't matter if the cam us rated "computer controlled" or not as long as it has no less than 114deg LSA and no more than 210deg duration at 0.050" lift. The rockers don't have to change at all but if you select a roller cam you have to use linkbar roller lifters and shorter puchrods and not the stock parts.
__________________
  #5 (permalink)
Old 10-20-2012, 05:29 PM
Power of 8's Avatar
1991 Ford F-250
Ok, thank you I know what to look for now
  #6 (permalink)
Old 10-21-2012, 10:34 AM
Power of 8's Avatar
1991 Ford F-250
What would happen if I installed a cam with a bigger lift such as this COMP thumpr 35-600-8 - Thumpr
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
