Multifunction Switch
Ok, my dads 2004 Expedition's multifunction (turn signal) switch lever broke off. Getting a replacement switch on order. Question is how do you remove the column cover to access the switch? I removed the screws holding the two pieces together but can not get it to come apart. Do I need to remove the steering wheel inorder to remove the column cover? Any help would be appreciated.
Thanks,
Jaime
Thanks,
Jaime
The two halves have little tabs that lock them together along the seams. Just grab near a seam and push and pull the top and bottom halves while pulling them apart. This is a brute force procedure.
fordinmudd
03-04-2011 01:36 AM
