2006 Ford F350 Super Duty Alternator Problem
I had a new FICM put in and the day I brought it home, the battery light came on. I had 2 6 month old batteries in the truck and I had the alternator checked, it showed bad. So, I replaced the alternator and recharged the batteries. The next day, after the truck warmed up, the light came back on again, so I had the alternator checked and it was bad. The two alternators were remanufactured, so I went and purchased a new one and the same thing happened. The wires have been checked and the battery connections have been checked and everything checks out good. What could be causing the Alternators to heat up and then fail? Help is needed. Thanks !
Rule #3 of automotive troubleshooting: Never assume a new part is a good part.
keating8070
09-07-2010 05:43 PM
Haoleman
02-19-2009 07:51 PM
