White smoke caused by ccv blockage?
Ok, so I tackled the CCV Mod this past weekend. The hardest part was running around the plumbing isle looking for what I needed to make it work. Put new orings for the doghouse and everything, then vented back to the intake.
Today after work, the truck was idling for about 10 minutes while I ran in the store for dog food. After getting back on the highway, I noticed heavy white smoke in the exhaust. I punched it real good and it cleared up after a quarter mile or so. About 12 miles I didn't notice anything, but had to pull off the road to clean up a bottle of windex that fell over and spilled everywhere. Idled for about 3-5 minutes and I noticed the white smoke again. Ended up making a pretty good cloud actually. Again, punched it real good and it seemed to clear up, but now i'm worried about a bad injector. When I got to the barn, I popped the hood and removed the oil fill cap to look for blow by, and there was a decent amount (but not really more than some of the videos i've watched in other posts saying it is normal). I'll do the floating cap trick tomorrow to compare, but anyway, That led me to notice that one of the hoses from the new CCV filter to the intake was kincked.
So, I unhooked the hose from the new tank to the intake and there is no more restriction there. I also noticed that there didn't seem to be anymore white smoke. Drove it a few miles and let it idle at my sister's house for about 10 minutes and still didn't see any white smoke in the exhaust. Drove the rest of the way home and let it idle for a few minutes and still didn't notice any white smoke in the exhaust.
So, I can't figure out how a blocked ccv hose could cause white smoke in the exhaust. I'm assuming it's just a coincidence, but if anyone knows, it's you guys. Could my white smoke have been caused by ccv blockage?
155K Miles btw, and the only thing i've done is gauges, K&N Intake, and CCV this past weekend.
New oil and filter less than 1000 miles ago, and replaced fuel filter at the same time. Full tank of diesel filled up this morning.
I'll check the blow by with the cap upside down tomorrow and report back, but i believe it's ok. I'm more worried about needing an injector, and figuring out which one is bad if that's the case...
Thanks in advance for the input guys.
Jeff
Jeff
Its from the oil leaking past the seals due to the extra pressure. Turbo would be my best guess.
Happened to me one night after dropping my tank, I flipped up the vent tube onto the frame rail and then forgot. About 40 miles later I looked in the rear view mirror and freaked.
Vent it to air and be done.
Well if you have the ccv with catch and back to intake you either have a blocked line, doghouse or it's the turbo seal on the compressor side. I think many times the doghouse needs to cleaned and check all lines. Also with a home made catch can you need to careful not to pack it too tight because then the catch can cause the restriction. Because positive crank case pressure is BAD!!
Brian now is this on your new engine?/ If so I would consider running it from the catch can to the exhaust. I am about to post up on an other tread "CCV modd revisited" with some issues I am having. I know alot of guys have run it straight to the air with no issue. But I myself like to try to keep my crank case pressure at a negative pressure. And if you are having these issues I think you might have too much negative crank case pressure if you are sucking oil vapors past the catch can. Or it could be because with the new engine the rings haven't seated yet.
greatwhitef350
10-30-2012 02:34 PM
powerstroker100
13
05-26-2010 01:06 PM
