Harmonic Hum/Moan
So, is it me, or does it seem a bit odd that these bearings "hum" that long before they really start sounding like a failure? Mine actually goes away up at 70MPH, and below about 35, but it sure feels like it is letting loose.
I somewhat wish it would go ahead and make some better noise.
Diagnosing is worse than the fix!
So do you have any play at all on any of your wheels.
I only have the play at the right rear. It's a very small amount of play but it is there.
I am trying to get to it, but may not tonight, the natives are restless...
I had a bit during the rotation on the right front. Just barely moved, so little that when the wheel was off, I had trouble duplicating it without the leverage the wheel gives you. Didn't think much of it at the time, but now with the conversation, I am wondering exactly how much we can get away with.
Finally getting a couple days to troubleshoot. Came home today and smelled brakes, and found the right rear had hung a bit. This happened once before. Not sure if a brake hang would do what this is, but sniffing into it.
Has anyone heard of a brake hang or resulting rotor warp doing this? I would think a warped rotor would show by some pulsing in the brake pedal, and I have exactly none of that.
I actually had it in yesterday for a tire balance. The shop said two wheels didnt have any lead at all on board, and two had less than 1/2 oz total. They didnt place any weight on the outboard side of the wheel, but it did tone down my vibration a fair amount. Enough I think I will take it back and have them balance better if they can using weight wherever needed.
I am still not convinced it is fixed, but I think I am at least sniffing the right tree.
ksulliv
02-20-2008 11:51 PM
Wakeboarder141
1978 - 1996 Big Bronco
05-14-2005 10:16 AM
