You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Sorry I misunderstood what you were asking. The computer is behind the plastic panel by the emergency brake. I have read the easiest way to change it is to loosen the drivers side fender/inner fender.
The ECU cannot be removed from inside the cab, it can be accessed/removed from inside the engine bay though.
Open the hood and look below and to the right of the master cylinder/brake booster and you will see the main harness. Loosen the main harness bolt (it's metric) and remove the harness from the ECU. There are also two nuts, and a rubber retainer, that hold the ECU in place (they're metric as well), remove the nuts and retainer. You will also have to remove some of the screws for the inner fender well so the ECU can slide out. Once you remove the nuts and screws, push down and away on the fender well and remove the ECU; it'll take a little work, but it's not hard and it doesn't take long at all.
__________________
Matt C.
Intercooled Vortech, Victor Jr. heads, roller cam, 62lb injectors, 2800 stall converter, Eaton Locker, Pickrel Headers and Exhaust, FMS Mass Air using SCT tuning software. Road trip and dragstrip ready!
