Exhaust before rear tires?
i'm going with 2.25" or 2.5" duals, with an 'x' pipe. dumping in front of the tires to the edge of the running boards. this is with a 4.6 small block mod engine.
thinking of using some nice quiet muffs and electric cut outs with 30"+ glasspacks. both pipes on each side connecting before the final turn for the exit. so i'm using the same tips for both noise levels...
Ok what does the "X" do for performance or whatever? Cuz i dont get how that helps anything at all.
I have a (1974 highboy STD Cab 8') 390 with mild cam (crower level 3 performance cam), short/ chassis headers, and seems like i can go with 2.5 or 3" exhaust.
What id like to know is the optimal setup.
A) do i do 2.5" or 3"?
B) do i need the "X" or do i just go straight to each muffler?
C) anything im missing
And what about 2.5" into the mufflers and 3" out? Good, bad ?
Currently i have the h, 2.5" in and 3"out
As far as the size goes either would probably be fine.
I just realized that you're not far from me. I'll be in Del Mar next Monday morning. I can bring the pipes if you want to see them.
<a href="http://s742.photobucket.com/albums/xx65/Fordworth/Exhaust/?action=view&current=IMG_20110920_135357.jpg" target="_blank"><img src="http://i742.photobucket.com/albums/xx65/Fordworth/Exhaust/IMG_20110920_135357.jpg" border="0" alt="Photobucket"></a>
<a href="http://s742.photobucket.com/albums/xx65/Fordworth/Exhaust/?action=view&current=IMG_20110920_135349.jpg" target="_blank"><img src="http://i742.photobucket.com/albums/xx65/Fordworth/Exhaust/IMG_20110920_135349.jpg" border="0" alt="Photobucket"></a>
Tying the two pipes together with either an X or a crossover helps produce torque. I don't remember all the science behind it but it has to do with balancing back pressure, exhaust scavaging, and resonance. The X set up is better and the closer you can get it to the collectors the better. One thing I don't like about it, though, is the sound. It takes a cool rumpity rump big cam idle and high throaty RPM definition and blends it all together making it a mellow drone.
Oh cool! I have scool though 8-10, then 1105-100ish, then back later Will you be driving the 75? Id love to see that sometime
And as for the X now im stuck cuz i like the way my cam sounds.....
I won't be driving the pickup, I'll be delivering a tractor to Fairbanks Ranch with the KW at 7:00 then picking up another at the horse park at Via de la Valle/El Camino Real after so I guess that won't work. After that I'll be making two more trips down there to pick up trailers from the horse park so maybe later would work out. If you're serious shoot me a PM and we can talk about it.
And a pm might be in order here
Here is what mine looks/sounds like. I also dumped mine in front of my rear tires for ease of installation. I just wanted to throw on something quick and relatively inexpensive so it sounded better than the burned out glass packs that were on there.
https://www.ford-trucks.com/forums/1...l#post11890548
#29
#30
