Setting 302 Timing - Ford Truck Enthusiasts Forums
Setting 302 Timing
Old 10-16-2012, 08:17 AM
rpatrick rpatrick is offline
rpatrick is starting off with a positive reputation.
Setting 302 Timing
After 2 years of part-time rebuilding, I finally finished reinstalling my 302 in my F-150 this weekend and fired it up and now need to set the timing.
Anybody have a procedure for doing this?
The manual says 10 btdc but it also says to follow the procedure in a powertrain manual that I don't have and does not seem to be in Alldata. I am thinking it is not just as simple as setting it with a timing light at idle - or is it?
This is a '93 with no vacuum advance.
Any pointers on how to get it set?
Thanks,
RP
Old 10-16-2012, 12:42 PM
Conanski's Avatar
Conanski Conanski is online now
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Assuming this is an EFI engine, start the motor and let it settle into a steady idle, connect the timing light, pull the spout plug to disable computer advance(grey plug in TFI harness), point the light at the crank balancer and turn the distributor until you get the setting you want. 10deg BTDC is stock but many motors will tolerate 2-4 deg more and that will make more TQ and improve fuel milage. When you got it where you want it snug down the distributor bolt, reinsert the spout, disconnect the light and take it for a test drive.
Old 10-16-2012, 05:15 PM
THANKS!
Thank you Conan - that is exactly the kind of info I was looking for.
Much appreciated!
RP
I need a diagram IDI guy 1994.5 - 1997 7.3L Power Stroke Diesel 4 03-01-2014 04:05 PM
Haynes Manual; not good! 4point2 3.8 & 4.2L V6 1 09-15-2011 08:35 AM
302 timing texaskid22 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 07-26-2010 09:45 PM
Alldata vs Chiltons vs Haynes dwilliamsceg 1999 to 2016 Super Duty 5 03-02-2006 01:14 PM
Alldata Question Meh! General Automotive Discussion 16 06-27-2005 01:07 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
