axle swap
axle swap
I have a '96 Bronco. I am considering doing a rears swap to make it 8 lug. I have both rears from a 97 F-250. The problem i have is the front antilock brakes. What can i do to make them work with the 8 lugger and not drive the computer crazy? If anyone has a suggestion I would appreciate it.
axle swap
[updated:LAST EDITED ON 03-Sep-02 AT 10:21 PM (EST)]Hmmm, you have both "rears?" I'm assuming you're calling a front axle a "rear," or something?
Anyway, what front end do you have to swap in? If it's a D44 you might be able to retain the wheel speed sensors ---------- but maybe not, since Ford SA 44's had 5 bolts for the spindle and TTB uses 6, and I think the spindle is specially formed to accept the wheel speed sensor???
The easier answer is to just forget about 4WABS, tie the wheel speed sensors up out of the way and remove the bulb from the dash.
EDIT: looking at your post more carefully you're talking about swapping in D50 TTB, hardly worth it IMO
dferrell5
30
01-25-2014 01:26 PM
4rdpwr
05-31-2003 09:44 PM
