OK guys when I fire my truck up it seams to run a little rougher than it should. I pulled the spark plug out of the 6th cylinder and it was wet and it was dark, I was thinking oil, so I dried it off and and pulled the plug from the 7th cylinder and it was dry as a bone so I put the plug that was in 7th in the 6th cylinder and put the plug that was in the 6th and put it in the 7th cylinder. I ran it for a few minutes and it was still sounding rough so I pulled the wire off of the 6th cylinder and it made no difference in sound. Then I pulled the plug out of the 6th and it was wet again, this time it was fuel. I tested the spark plugs in the wire and put it up against the manifold and it had a yellow spark in the middle and blue towards the end, shouldn't it be blue all the way through? I noticed that the top of the dizzy was loose so while it ran I wiggled it around and it didn't make a difference.
These were the problems I was thinking about
1. Piston Rings
2. Distributor Cap
3. Spark Plugs
4. Spark Plug Wires
5. Ignition Coil
What do you think is going on?
BTW the drivers side, 5-6-7-8 cylinders, tail pipe is smoking. I'm not sure if it is oil or if it is raw fuel. It seams to have a blue-ish tint to it (fuel) but I'm not 100%.
First, I'd change the plug... Then I'd swap that wire with another. If that still makes NO difference, I'd change dizzy cap. Years ago, I "upgraded" to a 'cap-adapt' with wider cap and better wires. Ran better during "wet creek crossings' during deer season. . .
is the probematic plug gaped properly and does it match the others? just a thougt i know the bigger the gap the hotter the spark but the more load on the coil to jump the gap
gauge all 8 plugs to make shure their the same i run my autolite plugs at .42...... granted im running a crane cams fireball 2 points eliminator kit in a new points dizzy with new cap n wires with a oriely electronic ign coil. im shure someone will chime in soon to advise on a proper spark gap...
seems a bit small .....i know mine wont run at all that small. id start at 38-40 although you could have something wong elsewhere couseing your spark to be weak...
