Turn Signal Flasher Problem
Turn signal flasher doesn't work in the heat. What gives?
All lights work. Turn signal stalk works fine. It just flashes a couple of times, then stays on. Everything works fine in cool weather, but it rarely works at all when the temperature outside is above 90 degrees. Very annoyed.
spookmeister
03-08-2018 01:22 PM
