Seriously torn right now.... - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 10-15-2012, 08:00 PM
JohnDeereFarmerUSMC JohnDeereFarmerUSMC is offline
JohnDeereFarmerUSMC is starting off with a positive reputation.
Well ive just about finished up all the minor details on all parts (including the motor, should be paying for it tomorrow), and my wish list from clay thats about to become reality.
(NOTE I HAVE NOT TALKED TO ROSEWOOD YET, JUST COMING HERE FOR AN OPINION, IVE READ ABOUT 50-60 INJECTOR THREADS TONIGHT AND IT MADE THE CHOICE MORE DIFFICULT!)
For my dilemma, injectors....oh the decision. Originally I had planned on using rosewood premium stage 1's. Now for the issue.....Is there any downside to going the budget stage 2 setup?
Quote:
Premium Stage-1/c: $1455 *Overhaul, converts to 160 cc Single Shots, new Plunger & Barrel assemblies, new Nozzles. With correct supporting mods, these are capable of around 325 hp.
Quote:
Budget Stage-2/s: $885 Overhaul, retains AB or AD fuel output, new nozzles flow 80% over stock. With correct supporting mods, these are capable of around 385 hp.
The stage 2's being significantly cheaper and allow for money to be invested elsewhere in the vehicle, my only concern is the performance differences between single or split shot...Im trying to gear this towards people who have ran stage1 or stage2 single AND split shots. Im honestly leaning more towards the stage 2's due to the cost, im only wanting to bring this truck to around 350, with 400 being the peak horsepower because it's staying a daily driver for the indefinite future. I need to hash this out so that way I can get my chip ordered, and will probably have a decision tomorrow or wednesday, just looking for opinions, the stage 2 setup seems too good to be true....
Man I cant wait to get this over with....was looking forward to it at first now im feeling a bit overwhelmed
Old 10-15-2012, 08:04 PM
BigAlsPSD's Avatar
BigAlsPSD BigAlsPSD is offline
BigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud of
Do you have enough oil would be my question.
I think you'll like the Singles better.
Old 10-15-2012, 08:07 PM
CSIPSD's Avatar
CSIPSD CSIPSD is offline
CSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to beholdCSIPSD is a splendid one to behold
His numbers are jacked up...
A 160cc injector with a stock nozzle will dyno ALL DAY, EVERY DAY 350hp...
An AD with an 80% nozzle will dyno about 350hp, will cause you nothing but issues with ICP...
A 160cc injector with a 100% nozzle will dyno at 400-425hp.
I have run modified split shot injectors. There is a reason why no one builds or runs modded split shots.
Old 10-15-2012, 08:12 PM
CSIPSD's Avatar
Quote:
<TABLE border=0 cellSpacing=0 cellPadding=6 width="100%"><TBODY><TR><TD>
The most common question I see for guys wanting to pick injectors is what to get and why.
There is a general formula I like to use that is 2.3HP for every CC of fuel that you can use effectively. Do these numbers jive with what everyone is seeing in the real world?
So figuring RWHP with an automatic trans. This takes into account horsepower peak happening between 2600-3000RPMs. All numbers based on single shots.
Here are some common injector combinations and the power level they usually accomodate. This also assumes you can maintain proper HPOP pressure.
I am also using common street nozzles 30% EH, 80% and 100% EDM nozzles. The larger nozzles allow you to push the power peak up into the higher rpms and make more HP. These are typical fuel only numbers because nitrous oxide allows you to peak the power lower in the RPM scale and make more peak torque and therefore more HP. There are so many variables that these are merely general guidlines.
General Rule of Thumb max power with no nitrous (but a properly matched turbo):
90cc stock nozzle 225HP
130cc stock nozzle 260-290HP
160cc stock nozzle 300-345HP
160cc 30% nozzle 350-360HP
180cc stock nozzle 300-350HP
180cc 30% nozzle 370-390HP
180cc 80% nozzle 400-425HP
200cc 30% nozzle 385-410HP
200cc 80% nozzle 400-440HP
200cc 100% nozzle 420-460HP
238cc 30% nozzle 440-475HP
(depends on air flow in lower rpms can make 550HP with nitrous for example)
238cc 80% nozzle 450-520HP
238cc 100% nozzle 465-550HP
250cc 30% not much gain over 238cc with 30%
250cc 80% nozzle 460-530HP
250cc 100% nozzle 470-575HP
It gets sketchy above that number due to the other variables that are involved with HP levels much above 550. Also remember that RPM can play a major factor. Somebody have corrections or want to add anything?
__________________
Matt Robinson
Gearhead Automotive Performance
</TD></TR></TBODY></TABLE>
Matt is one of the most conservative tuners on the market today if that gives you any indication of what a set of 160's are capable of making...
Old 10-15-2012, 08:23 PM
well joe i think youve just made my decision alot easier, thanks. Im going with rosewood because while the motors getting swapped i can run up and drop off the injectors and pick them up, its really for ease of mind to know that i wont be waiting on shipping and paying core fees, just trying to get the best bang for my buck.
Old 10-15-2012, 08:35 PM
Franko72's Avatar
Franko72 Franko72 is offline
Molon Labe
Franko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud of
I recently had Jim rebuild my injectors into stage 1 premiums. I absolutely love them over the stock splits.
The stage 1's are "premiums" priced higher because of the new plungers, barrels, and nozzles.
The stage 2's you listed were the budget build.
From my research new plungers, barrels, and nozzles are a "very good idea" when building an injector.
Jim is a heck of a nice guy and will answer all of your questions when you call.
I used to live not far south of Jim a few years ago myself.
Old 10-15-2012, 08:43 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Jim will post more conservative numbers on his injectors, part of which is because he's used to dealing with the OBS models with smaller turbo's, etc. The other part is he's a pretty straight forward guy and won't try to "sell" you stuff based on claims.
Not sure about saving money dropping them off though. Looks like you're about 400 miles away (what's a ground pounder doing stationed in MD anyway?) unless you've got the truck home on leave.
Old 10-15-2012, 09:09 PM
Texas Chain Ring Texas Chain Ring is offline
Texas Chain Ring is a splendid one to beholdTexas Chain Ring is a splendid one to beholdTexas Chain Ring is a splendid one to beholdTexas Chain Ring is a splendid one to beholdTexas Chain Ring is a splendid one to beholdTexas Chain Ring is a splendid one to beholdTexas Chain Ring is a splendid one to behold
Is the $1455 for new or re-manufactured single shot injectors?
Old 10-15-2012, 09:15 PM
Yea I've talked to alot of guys who went with jim and had good results.
Ill have the truck up there mid-november putting a new built engine in it, and and going with bigger injectors at the same time, as well as a slew of other upgrades. Trying to get on leave around nov10-13 and not returning till nov 30th so while i left myself some space (motor and everything will be sitting there ready to drop in all i have to do is pull mine, do some painting and cleaning and put the new one in), id like to go put a deer or two in the freezer and relax a bit while im there .
As far as being stationed in MD, im at indian head naval base, just across the river from quantico at CBIRF (Chemical Biological Incident Response Force), basically 2 sections 1 on 24 hour standby for 60 days and 1 off for 60 days, in case something goes down in the capitol region, although we respond pretty much anywhere (they went to japan during the most recent nuclear crisis from the tsunami, if thats what happened, i was busy winning a war in afghanistan). Pretty much where grunts go to die. Kind of a transition station for us, most of us have alot of medical (TBI, PTSD) issues etc. so we can utilize bethesda and get proper treatment before we get out.
Old 10-15-2012, 09:18 PM
Quote:
Originally Posted by Texas Chain Ring View Post
Is the $1445 for new or re-manufactured single shot injectors?
Pretty sure those are just re-man, with new parts. Not 100% as i havent had the opportunity to talk to them yet, ill let you all know what i find out tomorrow. Joe pretty much confirmed my suspicions with the split shot stage2's so ill more than likely be going with Stage1's rebuilds, like i said ill know more tomorrow.
Appreciate all the input, once again another reason FTE is my new home
Old 10-15-2012, 09:20 PM
CSIPSD's Avatar
Go with a 160/100 injector.
You will be happy. End of story.
Old 10-15-2012, 09:21 PM
Learning has occurred.
Old 10-15-2012, 09:22 PM
Casserly Full Force remanned single shots at Diesel Innovations for $1085.00. I think Riffraff is $10 more than that. Something isn't adding up with that cost you posted. New ones are around 2k.
Old 10-15-2012, 09:34 PM
Thats why ill be giving him a call tomorrow, if anything ill consider a different company and bite the 800ish pre-ship core charge and over night them back lol
Old 10-15-2012, 09:41 PM
Quote:
It might be a difference in nozzles if he's not using stock.
I'm not seeing the remanned on his site at but I know he has and sells them, he himself told me the brand and price including all new plungers and whatnot. He also makes his own performance injectors.
David.
Diesel Innovations Online Performance Diesel Products!
"F-150 OEM Filter and Fluid Specs smokersteve 2009 - 2014 F150 17 10-17-2016 03:57 PM
351 Windsor Build Micbruff 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 23 11-05-2014 09:17 PM
I'm pulling the trigger... need input! Tugly 1999 - 2003 7.3L Power Stroke Diesel 29 09-16-2012 03:30 PM
AC Injector Talk! Tugly 1999 - 2003 7.3L Power Stroke Diesel 33 09-08-2012 07:31 AM
Single Shot Sticks - Share Stories! Tugly 1999 - 2003 7.3L Power Stroke Diesel 17 07-12-2012 10:20 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
