1993 inline 6 - Ford Truck Enthusiasts Forums
1993 inline 6
Old 10-15-2012, 06:28 PM
Forddiesel11 Forddiesel11 is offline
Forddiesel11 is starting off with a positive reputation.
1993 inline 6
i have a 1993 Ford F150 4wd, its automatic, it has an straight 6 with 90,000 miles. i want a bigger tire. im thinking 32s or 33s but i want to know what i could fit on a stock rim. and i dont want to work the engine too hard. what would be your suggestion on a bigger tire size?
Old 10-15-2012, 07:22 PM
AbandonedBronco's Avatar
AbandonedBronco AbandonedBronco is offline
AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.
As for the rim, it's best to just give a quick call down to the local tire shop to see what they recommend as safe. However, you usually don't have to worry about that until you get up to 35"+ tires or so.
32s and 33s should do just fine for the engine. I know guys who have 38s behind their 300s, go rock crawling with them, etc., and have no issues.
It all depends on your gearing. Do you know what final drive you currently have? You'd most likely be just fine with either of those tires if you have 3.55s, or especially if you have 4.11s, but if you have 3.00s or less, you'll start to dog the engine and that's when you can cause issues.
ok experts... whistledip 1987 - 1996 F150 & Larger F-Series Trucks 2 05-17-2015 05:54 PM
How to get tires? copen93 1987 - 1996 F150 & Larger F-Series Trucks 9 04-03-2015 10:46 AM
38's and bigger on 6" of lift 79F250isalive! 1973 - 1979 F-100 & Larger F-Series Trucks 4 10-25-2014 11:44 PM
1993 Ford Brono 3inch Body lift Victorcorralsr 1978 - 1996 Big Bronco 4 01-28-2012 12:37 AM
ranger prerunner Clashem360 Offroad & 4x4 9 08-03-2011 05:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
