Walker pipe
Old 10-11-2012, 06:19 PM
Labhound's Avatar
Labhound
Labhound is offline
Walker pipe
I got my Walker down pipe for the efi manifolds today, mocked then up and noticed the front flanges don't match up .
[IMG]<a href="http://s1248.photobucket.com/albums/hh490/Labhound2/?action=view&amp;current=photo2-13.jpg" target="_blank"><img src="http://i1248.photobucket.com/albums/hh490/Labhound2/photo2-13.jpg" border="0" alt="Photobucket"></a>[/IMG]
[IMG]<a href="http://s1248.photobucket.com/albums/hh490/Labhound2/?action=view&amp;current=photo3-2.jpg" target="_blank"><img src="http://i1248.photobucket.com/albums/hh490/Labhound2/photo3-2.jpg" border="0" alt="Photobucket"></a>[/IMG]
Is there something I'm missing like a gasket?
This is the rear.
[IMG]<a href="http://s1248.photobucket.com/albums/hh490/Labhound2/?action=view&amp;current=photo1-14.jpg" target="_blank"><img src="http://i1248.photobucket.com/albums/hh490/Labhound2/photo1-14.jpg" border="0" alt="Photobucket"></a>[/IMG]
Old 10-11-2012, 09:05 PM
Triffecpa's Avatar
Triffecpa
Triffecpa is offline
looks like it fits to me. That type of exhaust joint doesn't use a gasket.
TR
Old 10-11-2012, 09:26 PM
Labhound's Avatar
Labhound
Labhound is offline
Only the rear fits, not the front, do you see the gap?
Old 10-11-2012, 09:28 PM
Triffecpa's Avatar
Triffecpa
can you not cinch those pieces together with the bolts?
Tracy
Old 10-11-2012, 09:41 PM
Labhound's Avatar
Labhound
Labhound is offline
Only if I do some relief cuts and weld then up, that's as far as it'll go.
Old 10-11-2012, 09:44 PM
Triffecpa's Avatar
Triffecpa
maybe you need some bigger bolts...
Sorry. Guess that I'm not helping much.
However, I'd heat the pipe with a torch before I'd go and make relieve cuts.
Can you loosen the EFI headers at the head and gain some room?
I ran headers on mine, so I'm not familiar with the EFI pipes and Y connector.
TR
Old 10-14-2012, 10:57 PM
kas83's Avatar
kas83
kas83 is offline
Use the Dorman exhaust stud kit for an EFI truck and you'll be golden. I have the Walker pipe on my 92, no issues at all. Only recommendation I would make is use some Copper RTV on the pipe at install, not necessary, but keeps things quiet.
Old 10-14-2012, 11:01 PM
kas83's Avatar
kas83
kas83 is offline
Dorman part 03135 is what I used to replace the original, rusty studs on my truck.
Old 10-14-2012, 11:04 PM
kas83's Avatar
kas83
kas83 is offline
Also, the 2 flanges didn't line up perfect on mine, but the pipe shifted/moved into place as I tightened the nuts, and has been fine for 6+ months now. Throw the studs in, tighten the brass nuts pretty snug, and enjoy.
Old 10-15-2012, 09:28 AM
AbandonedBronco's Avatar
AbandonedBronco
AbandonedBronco is offline
x2
There's flex in the pipe. When you tighten it down, it'll fall into place.
Old 10-15-2012, 10:35 AM
1986F150six's Avatar
1986F150six
1986F150six is offline
I cannot see where this has been mentioned in this thread, but be sure and check where the rear pipe is welded to the down pipe as some have found the the hole is not large enough... look down the back pipe and if not opened enough, some have used a hole saw or grinder to get the best flow.
Perhaps AbandonedBronco can share his experience.
Old 10-15-2012, 10:42 AM
AbandonedBronco
Unfortunately, I've never been able to open mine up, but it wasn't nearly as bad as some that I've seen! Next time I have my engine out, I would like to clean it up a bit more though.
It wouldn't affect fitment though.
Old 10-15-2012, 07:08 PM
Labhound's Avatar
Labhound
Labhound is offline
Thanks for that advice, I'll do that.
Old 10-15-2012, 09:05 PM
kas83's Avatar
kas83
kas83 is offline
Forgot all about mentioning the rear pipe. I bought a 6" carbide burr to clean mine up, very quick n painless. Mine had ~1" diameter hole to start, lots of slag from the torch cut on assembly.
Also, if you plan on running a cat, Thunderbolt has a 2.5" hi flow unit for $40 that fits perfectly in the drop section behind the O2 bung and rise for the trans crossmember. I'll see if I can get some pics of mine and have someone upload them, can't do it from my phone.
Arizona84F150
04-09-2017 09:05 PM
Franko72
60
04-13-2013 12:02 AM
StanleyZ
6.4L Power Stroke Diesel
06-23-2011 08:04 AM
Tedybear
03-24-2008 10:17 PM
franko
05-10-2006 01:12 PM
Quick Reply: Walker pipe
