Steering box splined shaft sheered off while driving...
2003 F250 7.3 crew cab 4x4, 107K miles. Taking the kids to school this morning, and bam. No steering.
Good thing no one died from the 7000+ lb truck in the on coming lane with no steering.
This is one of those parts that is never suppose to fail. It cant fail.
Ford, they don't care. Truck is out of warranty.. so its no sweat off their sack.
So, I'm out $454.10.
Nice.
Nice.
Makes me wonder why you could not make up a steering box stabilizer like they have for the Dodge Cummins.
Solid Steel Industries Steering Stabilizer 03-09 5.9L/6.7L Dodge Cummins 2500/3500
I have not put one on my Dodge but would love to, to see if it would tighten up the steering. (it has never been the same since that "one" trip off road)
I can't think of a reason that we could not do the same thing on a Superduty. If it supported on the end of the shaft, I would think that it would help keep it from breaking. I a guessing that the dropped pitman arm from the lift really puts some stress on the sector shaft. If you could remove that stress and only have to deal with the normal steering forces I bet it would last a lot longer. I will have to look into this further as i have the same dropped arm on my Excursion. It is the family ride so, it breaking is not an option.
For example:
1) Run large tires, steering box breaks; Ford is legally required to fix it (but they will try to worm out of it) because the tires didnt fail, the steering box did.
2) Buy aftermarket coolant bottle cap, and coolant bottle cap doesnt hold pressure, causing an overheat situation damaging the motor. Ford does NOT have to warranty this claim because the non-Ford approved item is the item that failed.
If his truck was under warranty they would have to fix it. Federal law states that an automotive company cannot require the use of any particular product, or brand of product with their vehicles as long as it is within specification and is not the failure you are trying to claim warranty on.
For example:
For example:
As soon as you modify the vehicle out of the specs it was designed with, you will have a tough time with warranty or lawsuits.
Even 35's can put more stress on parts, depending on roads, driving habits, offset, tires etc.
Wether you think it's 1% more stress than stock, or ford thinks it's 100% more stress, it doesn't matter because they can easily prove that you modified it outside of it's intended spec, even if that is only 1%.
I do think that a part such as that should have had a touch more quality put into it though.
Ford should have put a little more cash into the steering on these trucks.
on
Those examples are not really true, and only a small piece of a much larger story.
However, liability is a completely different issue.
For example, manufacturers crash test their vehicles at 45 MPH. Does that mean if you crash at 75 MPH and the airbags malfunction that Ford is not liable? I don't think so.
