Sending unit pickup screen - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 10-14-2012, 09:35 PM
96ford250 96ford250 is offline
96ford250 is starting off with a positive reputation.
I took the sending unit out of the old front tank and the little black piece with the screen was broken into a few pieces and rolling around the old tank I looked online and they are around $30 is there a cheaper mod or pickup that I can use?
Old 10-15-2012, 10:58 AM
farmert farmert is offline
farmert has a good reputation on FTE.farmert has a good reputation on FTE.farmert has a good reputation on FTE.
The cheapest way is to use a length of fuel rated hose clamped onto the picup tube where the "shower head" strainer was. Be sure to cut a V in the loose end so it won't suck to the tank bottom or side. The mod I liked better was to use a tube compression union and a length of copper tubing on the pickup tube. If I remember right you need a 3/8 union and tube.
Old 10-15-2012, 11:10 AM
I have the tube so that's no big deal but I can get a union easy and its a lot cheaper but I do have some fuel hose laying around and that free so maybe ill do that I want to put sumps in next summer
My Truck Dies On Front Tank midapo Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 21 04-22-2015 02:34 PM
1990 F350 sending unit back flow value and screen loadmaster3 1987 - 1996 F150 & Larger F-Series Trucks 5 12-03-2010 08:31 AM
Is this the right Unit? mward69 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 07-03-2008 01:14 PM
fuel sending unit screen ? RustyTrustyF150 Fuel Injection, Carburetion & Fuel System 4 10-07-2007 07:28 PM
Pull sending unit without dropping tank czaroc 1973 - 1979 F-100 & Larger F-Series Trucks 16 05-14-2007 08:41 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
