Can I Get an Honest Anwser?
For the weight you are talking about I would seriously think about a medium duty truck. Like you I have pulled 20K with trucks that are rated to pull half this (i.e.older F-250s), but my F-800 does it much more comfortably and with less drama. I also know that with the F-800 if my trailer brakes fail that it will not take to the other end of the county to get stopped.
I walked around the Ford lot tonight and to be honest, I'm not too impressed with these new trucks. For one thing they are expensive and their build quality seems fairly low for my standards. At this point, I'm seriously thinking about putting $10,000 into my old truck and walking away from the idea of buying a new one.
But what I did was I found a 99 Dodge Ram 2500 QC 4x4, V10 5 speed with 72,000 original miles from the original owner & made him an offer of $5500 a little over a years ago. I pull a 10,000 TT with ease. Get about the same mileage as a 6.2L gas Ford. The best part no (car note) or high license or insurance.
I have other than a few minor things (ABS sensor, T-Stat & gasket, washer bottle) just did a complete maintenance update.
Dodge in 99 did not make a 1 ton SRW 4x4 But this one is optioned out with 1 ton suspension. Dana 80 rear Dana 60 front, Heaviest GVW, the heavy sway bars etc.
I don't know what you have now? But it would be interesting to know what you have plus what you want to do.
Craig
I just got thru pulling my 24 GN with pallets of rock. I was only on back roads running a 30 mile round trip. lots of curves ranging from 40-65 mph. didn't have any problem - standard weight - truck& loaded trailer was 23,500. Made 7 trips. not an issue at all. the first load I was up at 27,600 and took it easy as I was on dual 7k axles and tires only rated for 4200 each.. truck/motor had no issues - just worried about the tralier...
I don't do that all the time but the truck doesn't seem to care when I put weight behind it. My weak link is my trailer - it is a little heavy empty weight - but with 8600 lb skid steer/ attachments it pulls well - weight police might not like me though..
