Steves' 49 f1 project
#31
Cut the bolts off and save yourself some trouble. Replacement bolt sets for the rear fenders are available from a couple of houses (including Mac's & LMC).
If you are pulling off the front clip, you'll be hours ahead by removing the fenders / grille / valance as a single piece - this is about 8 bolts. Then you can access the ~40 bolts holding the whole thing together.
DW
DW
#32
#33
You can cut/remove the bolts as a solo act. Getting the whole clip separated from the frame will take another set of hands. The clip isn't that heavy - it certainly is clumsy to handle.
I would also suggest that as you are ready to take the clip off, have a landing location in mind that doesn't cause new tears or bending on the fenders.
Good luck!
DW
Good luck!
DW
#34
Holy cow I set out to try and get the front fenders and such off the front so I can straighten the fron frame horns. But wth tons of the bolts are carriage bolts and even if I soak them in pb blaster they just spin. Loooks like I may have to cut them with my cut of wheel.
I'm going to try at alll costs to save the back fender bolts since they look like they will be hell to replace.
#35
I've removed many front clips by myself. Once you're done cutting and unbolting the bolts holding the clip assembly in place, get yourself a 4-wheel movers dolly (not the little one) and place it in front of the truck just about where the grille of the front clip would land once you pick up the clip. Then, pick up the clip from one side and slowly move and place the grille portion onto the dolly. The clip will stand right up and you'll be able to move it around by yourself.
#36
#37
WELP so much for having help, least I'm use to doing things by myself lol.
I spent about three hours to night working on my truck. The cut off wheel made my life thousands of times easier.
pulled the gas tank and heater
pulled off the monster of a rear bumper
cut the bed bolts and running board bolts to fenders. I ended up proping up the bed enough that the fenders cleared the tires and then i slide the bed to one side. I put down a heavy thick moving blanket and carefully rolled bed over.
can finally see the rear frame and springs..10 i believe in main leaf and 3 in overload..
took drivers running board off
went to work removing hood.
hood is off and safely set over in corner
Following several peoples advice i removed the bolts needed and pulled the whole front clip in one piece.
now i can FINALLY see how bad my frame is bent up front
And now i have a question....Does my passenger side cab to frame mount look bent or tweaked a little??? it looks different from the drivers side as far as how straight it sets.
#38
#39
Thanks yup about 3 or so hours and a cut off wheel, and a air hammer made shirt work of everything. As far as the frame goes I'm going to try and straighten and fix the front of it the best I can.
I wasn't sure about the cab mount so thanks again. I'm going to try tomorrow to get all the fenders off and unbolted. I was so dirty after laying under neith the truck using the cut off wheel and air hammer making dirt rain down on me, the water ran black during a shower.
#40
"If it doesn't make you bleed, or at least very dirty, then it's not really your truck!"
Well I guess you just earned your truck!!!!!
I remember needing a whole day to fully seperate a front clip.......just sayin'....
Oh......and get some 'old guy technology' for straightening that frame, cos 'rebending it the other way' aint the same thing as straightening it!!!!
#41
Yup, you've got some issues with that frame. The helper springs make me wonder if you have an F1 there. The stiffer springs only showed up on the F2s and larger trucks, I understood. Your bed looks to be the shorter F1 version. hummmm Well, I'm a bit baffled on this one.
The work space you have makes me want to put up that pole shed...
DW
DW
#42
Helper springs were available on the F1s. Both my 51 and my 52 have them. The 51 had them originally and I added a set to my 52.
The cab mount could be tweaked slightly. The force of the impact came from the right side, causing a "sway" to the left. This could also have shifted the cab to the left (from the right side impact), causing a slight twist.
You can get the frame straightened at a body shop that has a frame machine. A frame machine that has a laser measuring system would ensure that the frame is straightened to spec. You'll need to provide the frame specs to the shop and they can plug it into the computer and then hang the target points on the frame. It's a time consuming project.
You can also just "eye-ball" it when straightening. You can also do the straigthening with a floor pull system.
#44
#45
been a while and while i wait out my time i thought id practice some body stuff. I tried my hand at taking out dents.
I dont have any schooling on this, i basically watched a few youtube videos and just started doing it figuring out what works, and what doesn't. Thinking of buying a stinger type dent puller with slider hammer. Even if i only use it on this truck and race cars it would be worth it.
old picture is all i have of the dent on right rear fender
started taking out the dent
a few beers later
right front fender i worked on a few of the smaller dents leaving the HUGE on for later.
feel free to give advice or critique me as well..... just don't be to harsh lol.
a few beers later
