vacuum pump
vacuum pump
I am replacing my vacuum pump got the pump and the pulley off with no problem but can''t get the pulley back on at all. I have the tool and i tighten the bolt on then center nut down and when i hold the bolt and tighten the nut all it does is loosen the the bolt and it doesn't budge the pulley...What am I doing wrong?
thanks
thanks
https://www.ford-trucks.com/forums/9...cuum-pump.html Have a read here.
Unfortunately you don`t say what you are working on so I assumed it is a serp belt pulley.
ctann
20
09-25-2019 08:46 PM
rollingthunder-1
10-28-2008 09:43 PM
bill macparker
11-19-2004 10:13 PM
