"F-150 OEM Filter and Fluid Specs
First post contains Fluid specs. 2nd Post contains Filter specs.
Use Only Motorcraft Oil Filters and Transmission Filters.
Air Filters; it is acceptable to use any brand.
When it comes to engine oil filtes and transmission oil filters, nothing else can beat motorcraft.
The engine and transmission will degrade faster with a non OEM filter.
3.5L V6 Turbo
Engine Oil
6 Quarts
0W-30 / 5W-30 / 10W-30
Preferably 0W-30 or 5W-30
6 Quarts
Transmission Oil
13.1 Quarts
Mercon LV
13.1 Quarts
Mercon LV
Coolant Fluid
16.5 Quarts
Motorcraft Specalty Orange Coolant
16.5 Quarts
Rear Axle Oil
5.5 Pints or 2.75 Quarts
75W-140
75W-140
Front Alxe Oil
3.5 Pints or 1.75 Quarts
75W-90
75W-90
Transfercase Oil
1.6 Quarts
Motorcraft Transfercase Fluid
Any Mercon Transmission Fluid or form of Mercon works. For example III, V, SP, LV, or aftermarket.
1.6 Quarts
Brake Fluid
DOT 3.
DOT 4 can also be used.
DOT 3.
3.7L V6
Engine Oil
6 Quarts
0W-20 / 5W-20
0W-20 / 5W-20
Transmission Oil
12.1 Quarts
Mercon LV
12.1 Quarts
Mercon LV
Coolant Fluid
16 Quarts
16 Quarts
Rear Axle Oil
75W-140
75W-140
Front Alxe Oil
75W-90
75W-90
Transfercase Oil
1.6 Quarts
Any Mercon Transmission Fluid or form of Merconworks. For example III, V, SP, LV, or aftermarke.
1.6 Quarts
Brake Fluid
DOT 3.
DOT 3.
5.0L V8
Engine Oil
7.7 Quarts
0W-20 / 5w-20
7.7 Quarts
0W-20 / 5w-20
Transmission Oil
13.1 Quarts
Mercon LV
13.1 Quarts
Mercon LV
Coolant Fluid
17 Quarts
17 Quarts
Rear Axle Oil
75W-140
75W-140
Front Alxe Oil
75W-90
75W-90
Transfercase Oil
1.6 Quarts
1.6 Quarts
Brake Fluid
DOT 3.
DOT 3.
6.2L V8
Engine Oil
7 Quarts
0W-20 / 5W-20
7 Quarts
0W-20 / 5W-20
Transmission Oil
13.1 Quarts
Mercon LV
Mercon LV
Powersteering Oil
Mercon VCoolant Fluid
19.5 Quarts
Rear Axle Oil
75W-140
75W-140
Front Alxe Oil
75W-90
75W-90
Transfercase Oil
1.6 Quarts
1.6 Quarts
Brake Fluid
DOT 3.
DOT 3.
3.5L V6 Turbo
Air Filter FA-1883
Oil Filter FL-500-S
Transmission Pump Inlet FT-138
Transmission Internal Filter FT-188
3.7L V6
Air Filter FA-1883
Oil Filter FL-500-S
5.0L V8
Air Filter FA-1883
Oil Filter FL-500-S
6.2L V8
Air Filter FA-1883
Oil Filter FL-820-S
4.6L V2 V8
Engine Oil
6 Quarts
0W-20 / 5W-20
Coolant Fluid
16.4 Quarts
Mortorcraft Premium Gold Engine Coolant
Front Axle
3.5 Pints
75W-90
Rear Axle 8.8 / 9.75
5.5 Pints
75W-140
Powersteering
Mercon V
Transfercase Fluid
1.6 Quarts
Motorcraft Transfercase Fluid.
4.6L V3 V8
Engine Oil
6 Quarts
0W-20 / 5W-20
Coolant Fluid
15.8 Quarts
Front Axle
3.5 Pints
75W-90
5.5 Pints
75W-140
Powersteering
Mercon V
Transfercase Fluid
1.6 Quarts
5.4L
Engine Oil
7 Quarts
0W-20 / 5W-20
Coolant Fluid
16.9 Quarts
Motorcraft Premium Gold Engine Coolant
Front Axle
3.5 Pints
75W-90
5.5 Pints
75W-140
Powersteering
Mercon V
Transfercase Fluid
1.6 Quarts
Automatic Transmissions
2009
Oil Filter FL-820-S
4.6L 3 Valve V8
Air Filter FA-1883
Oil Filter FL-820-S
5.4L V8
Air Filter FA-1883
Oil Filter FL-820-S
2009-2010
4R75E
FT-150
6R80
FT-171
FT-138
4.6L V2 V8
Engine Oil
6 Quarts
0W-20 / 5W-20
Coolant Fluid
16.4 Quarts
Front Axle
3.5 Pints
75W-90
5.5 Pints
75W-140
Powersteering
Mercon V
Transfercase Fluid
1.6 Quarts
4.6L V3 V8
Engine Oil
6 Quarts
0W-20 / 5W-20
Coolant Fluid
15.8 Quarts
Front Axle
3.5 Pints
75W-90
5.5 Pints
75W-140
Powersteering
Mercon V
Transfercase Fluid
1.6 Quarts
5.4L
Engine Oil
7 Quarts
0W-20 / 5W-20
Coolant Fluid
16.9 Quarts
Front Axle
3.5 Pints
75W-90
5.5 Pints
75W-140
Powersteering
Mercon V
Transfercase Fluid
1.6 Quarts
2009
4R75E
13.9 Quarts
Mercon LV
6R80
13.9 Quarts
Mercon LV
2010
4R75E 4.6L V2 V8
13.9 Quarts
6R80 4.6L V3 V8
12.1 Quarts
Mercon LV
6R80 5.4L V8
13.1 Quarts
Mercon LV
13.9 Quarts
Mercon LV
6R80
13.9 Quarts
Mercon LV
2010
4R75E 4.6L V2 V8
13.9 Quarts
6R80 4.6L V3 V8
12.1 Quarts
Mercon LV
6R80 5.4L V8
13.1 Quarts
Mercon LV
4.6L 2 Valve V8
Air Filter FA-1883Oil Filter FL-820-S
4.6L 3 Valve V8
Air Filter FA-1883
Oil Filter FL-820-S
5.4L V8
Air Filter FA-1883
Oil Filter FL-820-S
2009-2010
4R75E
FT-150
6R80
FT-171
FT-138
The following users liked this post:
