"F-150 OEM Filter and Fluid Specs
The following users liked this post:
that appears to be correct.
171 = RWD
138 = 4x4
but I'm not sure that the list is complete as www.fordparts.com is showing two additional part numbers (FT-161 & FT-188) for the 6r80
best way to find the correct one is to go to the fordparts.com page, enter in your full VIN and then search for the transmission filter.
alternatively, you can call your local dealer's parts department and have them look it up based on your VIN. especially when the descriptions are less than perfectly clear.
I've had to do that a few times when several different part numbers appear to make sure you get the right one.
171 = RWD
138 = 4x4
Couple things have changed over the past few years... One is, I don't think I would use 0 W 30 in the Ecoboost... a good 10W 30 motor oil is needed.... Second is the antifreeze does not need to be from FORD... You can use any name brand DEXCOOL as it is ORANGE and rated for FORD and GM use.
That aside, I believe someone on the other F150 forum brought up a site that shows Motorcraft oils are actually pretty mediocre. No shock there as Ford isn’t in the petrochemical business. Hence, why the aftermarket exists!
ridgerkollyn - most people don't read their owners manual.
Owner's Manuals ««« -click-
» Select Your Year [ Choose One ]
» Select Your Make [ Choose One ]
» Select Your Model [ Choose One ]
FuzzFace2
15
05-21-2016 09:53 PM
