2003 Explorer xlt v8 4.6 P2197 - Ford Truck Enthusiasts Forums
Old 10-13-2012, 10:20 AM
yg101 yg101 is offline
yg101 is starting off with a positive reputation.
Question 2003 Explorer xlt v8 4.6 P2197
Newbie to this forum asking for some help..
I have a 2003 ford Explorer xlt v8 4.6 with a P2197 code.(02 sensor bank2 sensor1)
I had code P2195 a few months ago and replaced that 02 sensor but just recently truck threw code P2197 and is now starting to idle surge when I stop at a light or just leave it running in park.
Replaced PCV valve and the hose that goes from pcv valve to IAC also replaced Fuel Filter.
Cleaned IAC,Throttle Body and MAF did the old check for vacuum leaks with can of carb cleaner nothing found.
Any Ideas or past experience would be greatly appriciated... Pulled all coil packs off checked OHMs all read .6,coil boots looked to be in good shape going to replace spark plugs and 02 sensor tomorrow so I will post with results.
Thanks
Old 10-13-2012, 01:05 PM
aquanaut20's Avatar
aquanaut20 aquanaut20 is offline
aquanaut20 is starting off with a positive reputation.
Although most of the replacement items are maintenance, it would be beneficial to connect a LIVE DATA SCANNER and run through the diagnostics, rather than throw random parts... Philip
2004 Heritage 4.6 ~ 13 Diagnostic Error Codes leannacarol 2004 - 2008 F150 4 01-04-2016 08:02 AM
2010 F150 4.6L P2197 & P2098 GReich Modular V8 (4.6L, 5.4L) 10 11-25-2014 10:51 PM
code p2197 thunderbird1986 1968-2013 Full Size Vans 3 10-21-2013 08:30 AM
03 Expedition: Codes P2195, P2197 and P0171 MCGA Expedition & Navigator 10 07-23-2012 11:21 PM
Engine Code Help P2196, _2197 and P0171 MCGA Modular V8 (4.6L, 5.4L) 5 04-04-2012 02:23 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
