Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 10-12-2012, 04:05 PM
Shovelman Shovelman is offline
Garage is empty, add now
Shovelman is starting off with a positive reputation.
Questions on 7HA and 8MTH block interchangability
We recently purchased a '51 F-6 with 254 M series engine. It was stuck, so we pulled the head and freed it up. Upon inspection I found a small hairline crack running from inside the #3 intake port, extending across the deck and down the #3 cylinder about an inch. Just for laughs, we put it back together and got it running, drove it around a bit to see how everything else worked, and then pulled the engine for rebuild.
After disassembly and a 3 day bath in the hot tank, we looked things over and came up with a game plan for the crack which will include pinning and a liner for #3 cyl. Unfortunately, with the other machine work needed, we're looking at some serious $$$.
Here's the question: We found a 7HA 226 NOS bare block at a reasonable price. Could we bore the 7HA block to 3.500" and use all the parts from the 254 M? What are the differences in the blocks besides bore size?
Any help will be appreciated.
Thanks,
Scott
  #2 (permalink)
Old 10-17-2012, 10:24 PM
arnbobold arnbobold is offline
arnbobold is starting off with a positive reputation.
I had a 50 f6 that used the 254 ci, the engine went bad and we put in the 48 226 "H" block. We used the original intake system as of the vacuum set up. It was hardly any different in power as the 226 runs very nice.
  #3 (permalink)
Old 05-01-2013, 06:47 PM
f1ford48 f1ford48 is offline
f1ford48 is starting off with a positive reputation.
I know the head is beefier on the 254- you should call Chuck Mantiglia at chucks trucks hamden Conn- he might know
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
