what the hell? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
what the hell?
Old 10-12-2012, 02:27 PM
twarrior twarrior is offline
twarrior is starting off with a positive reputation.
what the hell?
my truck turns over, the wait to start light does not come on, & the 30 amp fuse in the fuse block under the dash keeps blowin out. Any suggestions?
Old 10-12-2012, 02:41 PM
windrider127 windrider127 is offline
windrider127 is starting off with a positive reputation.
Sounds like a diesel. Might post question over there. Which 30 amp fuse in the fuse block? As a guess, sounds like a malfunction in the heater circuit.
Old 10-12-2012, 02:47 PM
Thanx for the response and I did neglect to mention that I had 7.3 diesel. any way i did replace the glow plug relay and that's when i found out the fuse was bad cuz the wait to start light never did come on.
Old 10-12-2012, 04:37 PM
Shake-N-Bake's Avatar
Shake-N-Bake Shake-N-Bake is offline
Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.
Unplug the fuel bowl heater, replace the fuse and you'll be good to go.
The fuel bowl heater plug is on the back center area.
62 ECONOLINE FUSE BOX JOEPICKUP Ranchero & 1961 - 1967 Econoline 1 05-14-2012 09:37 PM
fuse box location drmitch Explorer, Sport Trac, Mountaineer & Aviator 1 03-24-2008 09:01 AM
Fuse for lighter? Turfscape LLC 1999 to 2016 Super Duty 8 10-13-2004 06:21 PM
Fuses or electrical??? whd507 1999 - 2003 7.3L Power Stroke Diesel 2 04-22-2002 08:39 PM
fuse??? TallPaul 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 07-31-2001 10:25 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
