Tail light fuse? - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Tail light fuse?
Old 10-12-2012, 02:52 PM
TXtinct's Avatar
TXtinct TXtinct is offline
You'll shoot your eye out
TXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputationTXtinct has a superb reputation
Tail light fuse?
Wondering if anyone knows which fuse it for the tail lights? My brake lights work but not the tails. The dealer just fixed all the recalls on my truck and I'm wondering if that could have caused this issue. Pretty sure they were working before that.
Old 10-14-2012, 11:45 AM
TXtinct's Avatar
Bump. Anybody?
Old 10-14-2012, 11:57 AM
Fordfleettech12 Fordfleettech12 is offline
Fordfleettech12 is starting off with a positive reputation.
Without an owners manual I wouldn't know. But to find ANY blow ato mini maxi or glass fuses, I use my test light. Clip it to a good ground, turn the ignition key to the on position, and touch the two metal tabs on the back of each individual fuse. Each fuse has two exposed metal tabs on their backs, touch the test light to each one, the test light should light on both tabs, if it lights on one side only, you found your blown fuse. There are a handful of fuses that won't light on either side, these will only have power during cranking. These are not taillight fuses. Good luck!
Old 10-14-2012, 11:58 AM
It's also possible that the taillight element in each bulb has burned out, don't rule that out either.
Old 10-17-2012, 10:18 AM
TXtinct's Avatar
It ended up being the bulb. There was a little bubble like the plastic had melted on the base of both bulbs. That's very strange.
Old 10-17-2012, 10:35 AM
dosecobanya's Avatar
dosecobanya dosecobanya is offline
dosecobanya has much to be proud ofdosecobanya has much to be proud ofdosecobanya has much to be proud ofdosecobanya has much to be proud ofdosecobanya has much to be proud ofdosecobanya has much to be proud ofdosecobanya has much to be proud ofdosecobanya has much to be proud ofdosecobanya has much to be proud of
Strange indeed. Those are LEDs too right? Did you get a pic?
Old 10-17-2012, 10:47 AM
TXtinct's Avatar
Quote:
I did indeed. I thought you might like to see it. I just found it odd that the brake lights still worked. I wonder if the recalls that were done had anything to do with this. They worked fine before I had all my "electrical issues" a couple of weeks ago.
Old 10-17-2012, 10:56 AM
hmmmm? What recalls? Do those lights have resistors built in, I didn't check before I installed mine.
Old 10-17-2012, 11:01 AM
TXtinct's Avatar
I don't recall if the lights have resistors. I'll have to check on the recalls, they said there were a few. I read on another thread that this happened to someone I just can't find where I read it now.
Just my tail lights are out on a 2011 F250? jbullfrog 1999 to 2016 Super Duty 15 12-16-2016 05:26 PM
Tail light troubleshooting advice MCD46 1961 - 1966 F-100 & Larger F-Series Trucks 8 12-12-2013 04:01 PM
Dash lights CPorter 6.0L Power Stroke Diesel 0 06-05-2013 10:27 PM
What number fuse are the trailer tail lights? bar20 2004 - 2008 F150 4 07-13-2010 09:48 AM
Brake light failure(Tail lights) jamrock Electrical Systems/Wiring 4 02-23-2007 12:50 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
