To syn or not - Ford Truck Enthusiasts Forums
To syn or not
Old 10-12-2012, 12:52 PM
smoore0531's Avatar
smoore0531 smoore0531 is offline
smoore0531 is starting off with a positive reputation.
To syn or not
Would like to start using synthetic oil in my truck, just want to make sure to not mess it up. Is there anything I need to do special during the oil change?(specifically to flush out old oil). I have 140k on my motor and bought it used so I am not sure what oil the old owner used. Can I safely switch to synthetic? Thanks for your time---Stan.
Old 10-12-2012, 01:05 PM
69cj's Avatar
69cj 69cj is offline
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
Yes you can. The best regularly priced syn. oil I've found is Rotella T-6 5w40 at Walmart. However any major brand API CJ-4 rated oil will be fine if you find some on sale. If need be you can also switch back with out any harm to your motor. Just for your reference the 6.0 retains approx. 4 qts. of oil in the engine when doing an oil change. Make sure you use only OEM filters in the 6.0. She don't like A/M's.
Old 10-12-2012, 02:21 PM
gunnarGSD gunnarGSD is offline
gunnarGSD is starting off with a positive reputation.
You should have no issue at all just it change normally using OEM filters, no special procedure. You will never get all the old oil out so don't worry about it, it wont hurt a thing. I use Rotella T-6 5W40 and my truck loves it especially in the Canadian winters.
V 10 eingine oil stan'37 Modular V10 (6.8l) 1 01-10-2014 10:10 PM
'94 3.0L Burning Oil... Traxxis Ranger & B-Series 0 06-14-2009 12:36 AM
High Milage Oil stan_02ranger Oil & Lubrication 52 05-03-2007 01:45 AM
synthetic test results. stan merck Oil & Lubrication 33 07-27-2004 09:58 AM
Stan's headers idahocrewcab 1973 - 1979 F-100 & Larger F-Series Trucks 7 01-19-2003 01:07 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
