motor problems
motor problems
I have an 89 F 150 the truck runs fine until it warms up and then all die it will start back up about 10 minutes later. at first I thought it was just vapor locking but it did it to me when it was about 20 degrees outside after running for about 20 minutes I don't know what the matter is
Yes you got the right thing. I can say surely that it is a poor spark problem. You can check the spark plug also. Sometimes the carbon stuck on the spark plug and it is the cause. Gud luck for your f150...
wheelchair access conversions
I have watched the tack while it starts acting up your drop 0 go right back up to 1500 rpm drop back to 0 start back up to 1500 and then dies. I have replace the coil the spark plugs wires cap and rotor and had the distributor modular checked and they should all be good
