Time for carrier bearing & U joints - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 10-12-2012, 09:56 AM
Franko72's Avatar
Franko72 Franko72 is offline
Molon Labe
Franko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud of
If I can round up the parts I'm going to tackle the drive shaft today. @284k and all of the towing I do, it's prob a good idea to get some new greasy parts under there.
So I've been doing some reading about "drive shaft phasing" and honestly I never even knew about the importance of it... During my "three transmissions in two months" debacle I had the shaft in & out a few times and never once "phased it" going back in.
I'm not sure if the guys at BTS checked it upon reassembly or just put it back the way it came out
So my question is: do I just make sure that all of the yokes are in line front to back and I'm good? or is there more science to it? I doubt my shaft was ever marked so I'm going in blind.
Any and all help will be appreciated
I also have a can of the magic Ford slip joint grease Thanks to Mark (Tailgate77478) So I'll slip into the dealership and pick up a rubber boot kit as well.
Old 10-12-2012, 10:14 AM
Tugly's Avatar
Tugly Tugly is offline
I'm a cautionary tale
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
Subscribing - bumping my HP bumped this project onto my priority list.
Old 10-12-2012, 10:19 AM
Pitcrw6's Avatar
Pitcrw6 Pitcrw6 is offline
Pitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant future
Subscribed as well
Old 10-12-2012, 10:23 AM
Fat Diesel's Avatar
Fat Diesel Fat Diesel is offline
Fat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud of
I recommend a new slip joint as well. I've replaced the u joints and carrier bearing twice and the last time I should have replaced the slip joint. I'm starting to get vibration, especially when letting off the throttle.
I understand the concept of phasing, but are these two piece drive shafts really phased? Not sure about the answer to that. However I usually spray paint a line on any driveshaft I do anyway.
Old 10-12-2012, 10:36 AM
BadDogKuzz's Avatar
BadDogKuzz BadDogKuzz is offline
BadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud ofBadDogKuzz has much to be proud of
Frank I would start by looking very closely to the driveshaft because I am sure Brian or his guys marked the driveshaft before pulling it out. I myself took a hammer and metal chisel and stamped a arrow at every yoke and on the ends of driveshaft. And as far as "phasing" I say as long as you take it apart and put the shaft and yoke in the same place you won't have an issue. I personally think leave it to the Pro's... I mean by that at 284k replace ujoints, cb and have the thing balanced. Everytime I replace ujoints on "anything" I have the driveshaft balanced. It only cost around $100 and if it isn't "phased" they can fix that when balancing. Some guys here seem to worry more about phasing than balancing.
And as heavy as you tow and the distances you go I would want it balanced. I would look into a driveshaft shop and see what they want to do it. Besides on the carrier bearing there are 2 sizes and I do believe our CC 2wd drw is the larger of the two. Dana #211359X bearing ID1.574 but that is what Dana calls for and ujoints 5-160x or 5-801 series 1410. And I would use Spicer or Percision, I would not use junk part store brand. I learned that one years ago.
Hope this helps!
Old 10-12-2012, 10:43 AM
DISLFVR's Avatar
DISLFVR DISLFVR is offline
Locomotive breath
DISLFVR has a very good reputation on FTE.DISLFVR has a very good reputation on FTE.DISLFVR has a very good reputation on FTE.
Quote:
I believe they are, especially what I went through with mine. I couldn't figure out where the vibration was coming from until I started digging into it. I looked at mine and the front yoke and slip yoke were off by 45 degrees or so. Took it apart and lined them up and I couldn't believe the difference. If they are off, the universals are working against each other, in phase they work together.
BadDogKuzz's Avatar
And I forgot one thing as far as the slip joint. As long as the coating on the splines is not damaged or wore off it is good to go. I myself use Mercury Spline grease it has a higher shear rate than any automotive grease. And as long as your boot is good I would only replace the bands. You can use large wire tie, exhaust wrap tie straps or stock banding clamp.
Old 10-12-2012, 10:01 PM
Franko72's Avatar
Molon Labe
Ed, thanks for the part numbers I used Precision solid U joints. They gave me the wrong carrier bearing, and it took a few stops to track the right one down.
I should have just had a shop do the whole job for me, I scrapped one U joint (because I'm impatient ), and I had a wrestling match with the carrier bearing...coming off and going on. The job took a lot longer than expected but it's finally done.
The 40mph & 70 mph vibration is completely gone!!
The slip joint looked great. Plenty of blue coating and grease, I probably could have left it alone, but a new can of Ford teflon slip joint grease has been in my rear cup holder for over a year. I just had to use a little...
Old 10-13-2012, 09:55 AM
BadDogKuzz's Avatar
Quote:
I should have just had a shop do the whole job for me, I scrapped one U joint (because I'm impatient ), and I had a wrestling match with the carrier bearing...tcoming off and going on. The job took a lot longer than expected but it's finally done.
Well I glad to hear you got it done and that you are good to go. Was the carrier bearing the ID 1.574 bearing or was it the smaller one?? Because when I was doing the research on that it was a little unclear.
I am glad to hear you went with the Precision solid U joints. Are you talking about the ones that have the grease fitting in the cap or solid with no grease fitting? The Spicer u joints are alittle more costly but I have used Precision U joints in the past with alot of luck. Good stuff I had book marked the Spicer #'s I gave you and the Precision #295 what part# did you install? Also what brand carrier bearing did you install I couldn't find a Precision or anyone who carries the Spicer.
I still haven't done my, they are still the factory ones with 205k . I thought I had a bad carrier bearing back when I was having trans issues but it ended up being the center support in the trans. So I still haven't gotten around to doing the u joints and carrier bearing. I still a vibration but I am unsure if it a wheel bearing, tire or u joints. I am leaning forward my wore out front tires. Speaking of tires how are you liking them new rear tires?
Old 10-13-2012, 10:11 AM
BadDogKuzz's Avatar
OOpppss Double post....Sorry
Old 10-13-2012, 10:51 AM
Franko72's Avatar
Molon Labe
The first carrier bearing wouldn't fit over the splines of the drive shaft, My buddy took it back and Autozone claimed the 1.574 ID was for a F450, but it was correct and fit just fine. ( Timken HB88508A)
The Precision U joints were solid with no grease fitting, I didn't write the part number down, and the boxes are long gone I got those at Napa.
I still have yet to get the tires installed. I should get that done this week sometime.
Old 10-13-2012, 12:20 PM
Texas Chain Ring Texas Chain Ring is offline
Texas Chain Ring is a splendid one to beholdTexas Chain Ring is a splendid one to beholdTexas Chain Ring is a splendid one to beholdTexas Chain Ring is a splendid one to beholdTexas Chain Ring is a splendid one to beholdTexas Chain Ring is a splendid one to beholdTexas Chain Ring is a splendid one to behold
I bought a carrier bearing from Autozone, zero issues so far. Lubed the spline fitting at the same time. The little "thud" I had upon take off stopped, all tight.
Old 10-13-2012, 12:39 PM
ToMang07's Avatar
ToMang07 ToMang07 is offline
ToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant future
Here's a good read:
Old 10-13-2012, 12:46 PM
BadDogKuzz's Avatar
Quote:
Originally Posted by ToMang07 View Post
Thanks for posting this, it is a good read Alots of great info.
Old 10-13-2012, 12:52 PM
ToMang07's Avatar
It definitely helped me get some stuff straight!
Passenger side drive axle u-joint phasing gb5 1987 - 1996 F150 & Larger F-Series Trucks 2 12-19-2016 02:22 PM
F3 Drive Shaft Out of Phase? Scotty's 52 F3 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 09-08-2015 12:21 AM
Drive Shaft Phasing 250 STROKER 1999 - 2003 7.3L Power Stroke Diesel 2 11-27-2014 06:12 PM
Dana 50, passenger side axle - ujoint phase Lukes66 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 08-19-2014 03:18 PM
Rag Joint 1983F1503004x4 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 03-05-2013 12:57 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
