79 f-100 front end sagging
The front end being lower than the rear does not mean the springs are 'shot" although they may be. Someone could have built up the rear springs, quite common to see. If the fronts are weak you'll have a camber problem. Check all bushing. It may take some effort to determine exactly why your front end is lower than the rear.
Edit: There were several different spring ratings for this series truck.
ryans428
06-01-2005 08:31 PM
Jet Lizard
08-13-2004 10:25 AM
Benford79
10-29-2003 09:29 PM
therigwelder
07-11-2003 09:13 PM
