Wheelskins Leather Steering Wheel Wrap
Well, the RTV method didn't work either, so I cleaned it all off. I've tried wrapping different types of string around the notches to build them up. It doesn't work, because the notch is not an even thickness all the way around. I've spent several hours trying to make things like neoprene foam rubber, pieces of bicycle inner tubes and so on trying to fill the notches. I know none of these methods are the correct way to go about doing this. LOL...
I'm about ready to throw this steering wheel in the trash. Haha... Does anyone have a nice regular non leather steering wheel that has the cruise control setup? I think the best thing to do is to install the Wheelskins on one of those.
I'm looking at possibly using something like this JB Weld plastic repair epoxy putty to fill the voids in the wheel. I'm also looking at Loctite repair putty. Do either of these seem like a good idea?
J-B PlasticWeld | Plastic Repair Epoxy Putty
http://www.loctiteproducts.com/p/epx...ti-Purpose.htm
#29
Home Depot had the JB Weld plastic putty. It also says its semi flexible. That should be a good thing for this application. It was fairly easy to use and not really messy except getting it off your fingers. What I did was roll it into a round strip a bit bigger than the gap, wrap it around the wheel, press it firmly down in the groove, and smooth it out. I hope it's smooth enough. I guess I'll find out later today, if you can feel the repair through the cover.
#30
Eastwood products has what your looking for, now if I can find the link.
*edit* found it
Complete Steering Wheel Restoration Kit
*edit* found it
