beyond pissed now
beyond pissed now
whats the trick to get out fuel filter on a 04 explorer.im not no retard when it comes to working on cars but this has me at a stand still.the line that comes out of the filter is whats giving me problems.i have try'd every ac/line tool there is,plastic and metal and i cant get the line off the filter. please give me some info.thanks Joey
some seem to be a real PITA. basically all work the same, push the tool into the coupling and make sure it is all the way in, then pull the coupling off while holding the tool in. sometimes it tricky due to the location of the filter. my 2002 is about impossible to get to up inside the frame rails and muffler.
i wish i had seen this prior to replacing the fuel filter in my '04 explorer.
i had to cut the fuel filter outlet pipe at the filter, remove the filter and bracket so i could get a better view of the spring( inlet is a breeze) and attempt to use the plactic tool. i could hear the "click" of teh spring being released, but i could not get the stub out.
Now its on!
i wound up using a piece of 3/8' copper that i was able to increase the internal size slightly so i can release the spring and pull the stub out.
Needless to say, after spending 8 hours to replace a simple filter, i was victorious!
Now its on!
Just changed the filter on my daughters 04 last sunday. Heard and felt the plastic tool click but could not get the line off. Fought it for a hour then went and bought the anodized aluminon set that Harbor freight sells. Came right off. Looks like I burred the plastic tool somehow and that kept it from coming off.
-Rod
Agreed. That's what I ended up having to do on the fuel filter of my prior 2000 Mountaineer. I was about to give up and tried pushing the two together, then the tool slid in like butter and came apart with ease. I couldn't believe how easy it was when I pushed the end towards the filter body. I'm not sure if I got lucky at that point of if that's how it was supposed to work. I already had one side loose (after a fight) so I didn't get to try that trick out again. I haven't tackled the one on my 2004 Aviator yet.
-Rod
-Rod
Coccyx
27
07-06-2013 06:57 PM
