ok while pumping the reservoir to change my IPR the plastic straw piece from a soap pump fell into the reservoir. if i cant fish it out what are my options?
do i have to remove the HPOP to get into the reservoir?
hope u all help-ty
The upper resivour is sealed to the timing cover with a oring type seal if you have to pull the resivour to remove the straw.i would replace the seal if i had it off.should be easily found.i replaced mine as it was leaking...320xxx mi.
Yep.pretty much.real easy to do.then u also can clean the hpop resivour good.i did mine and it is amazing how long clean oil stays nice after an oil change lol
