Difference in intake manifolds
Ok, I have the head off and measured the intake ports on the two manifolds and the head, here they are;
Head = 1.3" wide x 1.92" high
Edelbrock = .975" wide x 1.8" high
Iron 4bl = 1.65" wide x 2.125" high
Which would you use?
Can I safely open up the Edelbrock to match the head?
Thanks again,
Ray
Thanks again,
Ray
I would gasket match both the head and intake. You will likely have better results with the aftermarket intake's smaller ports, though, since I doubt you will be able to open the head to match the iron intake. With larger ports on the intake, the charge will be hitting a wall all around the head port, and this will significantly reduce the efficiency of the engine.
VitaminC
03-31-2014 07:00 AM
whackit
17
10-14-2012 07:22 AM
JOHNNEHUS
07-21-2007 11:58 AM
FEmtnmax
11-10-2005 05:32 AM
