52 F6 Replace T98 Transmission - Ford Truck Enthusiasts Forums
Old 10-11-2012, 04:52 PM
hulaman's Avatar
hulaman hulaman is offline
hulaman is starting off with a positive reputation.
Hello all,
I drained and replaced the gear oil in my crash box. And just as I suspected there was a lot of metal in the mix. A few large pieces the size of a small nail clipping and the rest was just gritty.
It's been jumping out of gear lately and being 60, she's been around the block.
Question is... rather than rebuild or replace this one, what it the best transmission swap? Those familiar know I have to double clutch on every gear change. I don't want to do that anymore.
I prefer to keep the manual setup with shifter on the floor. I have a FHV8 with dual speed rear end. Remember, it's a 2 ton flat bed.
Thanks!
Old 10-11-2012, 05:10 PM
hulaman's Avatar
OOPS... maybe I don't have a T98... if I have to double clutch... that means unsynchronized... and the T98 is synchro...
I do know it's a 4 speed manual transmission... and reverse is far to the right and down
Old 10-11-2012, 05:20 PM
hulaman's Avatar
Wow,
Sorry guys, I answered my own question with my question. I found the shifting pattern of the two transmissions. A Synchro reverse is to the right and UP, non synchro is DOWN.
Looks like it's the T98 I want, not the one I HAVE... <egg on face>
Old 10-11-2012, 09:36 PM
cstempert's Avatar
cstempert cstempert is offline
cstempert is starting off with a positive reputation.
The T98 was available with the big 6 in 52 only. The rear trans mount is specific to the 48-52 so later guts will work, but you need the 52 case.
I have 2 now, one to go in my F6, the other needs to be rebuilt.
Also, if the rear bolts on the crossmember have nuts, its a crashbox. Or just pull the pto and clean out / inspect the gears.
Quote:
Originally Posted by hulaman View Post
Wow,
Old 10-11-2012, 11:03 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
The T98 was the standard transmission behiind the 254-6 in at least 1951 and 52. I've had them in both. My understanding is that is was also an option with other engine combinations, but I wouldn't swear to that fact without further documentation.
I'm not sure what you were meaning by the "guts will work," but the cases are totally different between the T98 and the crashbox 4 speed. Guts don't swap between them.
Old 10-12-2012, 08:33 AM
cstempert's Avatar
Sorry, to clarify, I meant the gears in a later T98 will fit into a 52 T98 case, but later T98 cases don't have a rear bracket to mount in the early truck. So you can source a T98 from a 53 or later truck, but you will still need a rear bracket from a 52.
As you said, the T98 and spur gear trans are completely different inside.
Old 10-14-2012, 09:16 AM
CHUCK48-50's Avatar
CHUCK48-50 CHUCK48-50 is offline
CHUCK48-50 has a good reputation on FTE.CHUCK48-50 has a good reputation on FTE.
Hello all,
Thanks!
The best swap for you would be a T-98. Only the first version will work. It was available as an option from 1950-52, models F-4/6, with any engine, and came standard in any 1950-52 F-6 with the 254 6 cylinder. It must not have really caught on until 1952, because that's the most common year truck you will find one in.
The common T-98 that was in F-100/600's 1953-55 can be used for it's internal parts, with the exception of the input and output shafts. The top is also the same, but the case is completely different, and won't interchange. In 1956, the angle of all of the gear teeth was opposite, so nothing will interchange except for the top. Also, the shift lever is specific to 1950-52.
Chuck
Old 10-15-2012, 01:54 PM
hulaman's Avatar
Thanks Chuck!
I am going to keep an eye out for one so I get it on my terms...
instead of when I HAVE TO.
-chris
2005 E-450 Transmission Help daBeaver 1968-2013 Full Size Vans 5 07-07-2016 09:03 PM
Aerostar transmission won't shift BigLoo Aerostar 1 01-17-2014 06:58 AM
Transmission occasionally shifting strangely... seebeexee 1994.5 - 1997 7.3L Power Stroke Diesel 8 06-09-2013 10:32 PM
Erratic Speedometer and transmission anomaly gossett.air Clutch, Transmission, Differential, Axle & Transfer Case 3 08-15-2010 05:48 PM
Is there a way to test the clutch? f250_kinda_girl 1987 - 1996 F150 & Larger F-Series Trucks 10 09-21-2009 05:33 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
