Limits on propane horsepower ? - Ford Truck Enthusiasts Forums
Old 10-11-2012, 10:11 AM
parkland parkland is offline
parkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud of
Hey,
Just wondering......
What is the limit on propane power?
I mean, if you have and engine that puts down 200 hp or whatever, why tinker with fuel pump upgrades and such if you could add the power with propane and keep the stock injectors and fuel system so it runs right...
So many trucks with hopped up fuel pumps and shower head injectors, sure power is nice, but is propane a viable option if you want big power on a truck that runs nice as a daily driver?
Old 10-14-2012, 09:02 AM
nitrogen's Avatar
nitrogen nitrogen is offline
nitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant future
yeah there is a limit. since it is fed in through the intake and not direct injection, there is no control over timing. as a result excessive propane will give you very high cylinder pressure and temperatures. at that point things don't last long. done within reason it can be impressive, go nuts and it will be a whole nother kind of impressive. done right it adds to the power, without being the main fuel source. since there is already some fire in the cylinder(from the propane) the diesel ignites more easily and quickly when injection occurs
Is Propane or water/MEOH Injection worthwhile? thedaddycat Bio-diesel, Propane & Alternative Diesel Engine Fuels 7 04-05-2008 12:42 PM
fuel injecting propane pud Alternative Fuels, Hybrids & Mileage 3 07-02-2006 10:21 AM
I have a problem with the fuel system mytruckiscool 1987 - 1996 F150 & Larger F-Series Trucks 2 08-15-2005 11:13 PM
Propane/Fuel 79 F-250 CrewCabCOE Alternative Fuels, Hybrids & Mileage 3 04-03-2005 01:21 PM
Propane System on a 4.9L F-250 abelmoreno 1987 - 1996 F150 & Larger F-Series Trucks 0 01-24-2005 09:31 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
