Who is running a Titan tank on a CC SB?
Question for those of you running Titan tanks - where does the extra capacity physically come from? As in, does the tank extend farther forward, backward, up, down, etc... maybe it's some of all of these? I've got some accessories mounted to the frame near the fuel tank and I'm wondering if these would be in the way of a Titan tank.
I'm considering getting one because we are planning a couple of longer trips with the TT in the next year or so, and I don't like having to fill up every 200 miles.
Anyone have any input and/or pictures?
Thanks,
- Steve
Thanks,
- Steve
They mainly hang a lot lower, but also get closer to the driveshaft, and I would assume they extend forward into the dead space behind the transfer case as well, since there's only so many ways to almost double the size of the tank. I know Titan isn't the exact same as Transferflow, but since there's only three dimensions to work with, and since the Titan is 4 gallons larger than these pics, the odds are the Titan won't be physically any smaller than the TF:
Ford tank ground clearance
