Instrument Cluster 1978 Ford Truck - Ford Truck Enthusiasts Forums
Old 10-10-2012, 09:17 PM
Robot_2008 Robot_2008 is offline
Robot_2008 is starting off with a positive reputation.
Was looking around at a yard today and found an instrument cluster in a 1978 pick up in pristine condition - no rot or anything. Considering the hassle I had finding one not too long ago for a 76 (had to have the after market base installed etc.) I thought I'd post the find here in case anyone is looking for one.
If I remember correctly, this is a tough part to get without rot but I don't know which models etc it will work on. Sorry I didn't get more info like part number and so on but if I get back up there I'll post again.
What I can report: Cluster from a 1978 F 250. From L to R, Top to Bottom- Oil, Gas, Speedo (Center) Alt and Temp. Sorry I don't have image or more info but was rushing.
Yank-A-Part Poulsbo, WA 360-779-3344 Quoted me $35. Hope this helps.
Bot
Numbers Dummy, need your help!! GM4WALLS 1973 - 1979 F-100 & Larger F-Series Trucks 8 03-05-2016 08:27 PM
Do I have one problem, or two? Instrument Cluster and 4x4 Eccles 1999 to 2016 Super Duty 2 02-19-2016 12:50 PM
My “How To” install a F-150 Cluster w/Tach into an Aero 93nighthawk Aerostar 39 09-23-2015 09:55 PM
Custom Instrument Cluster- Need advice silar 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 12-19-2014 08:47 AM
Instrument Cluster Replacement Ole Green 1978 1973 - 1979 F-100 & Larger F-Series Trucks 5 01-23-2012 10:37 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
