Fuel leak
If it is still leaking after you rebuilt it, It can only be one of about three issues.
1-You cut an o-ring putting things back together
2-You have holes rotted into the bottom of the fuel bowl itself
3-It is leaking from somewhere else (fuel pump, rubber hoses, etc...)
And for the money, I would fix the fuel bowl, or put the $300 towards e-fuel instead of spending that much on another fuel bowl. That or I am pretty confident that you could find a used one for a lot less than that. Shoot there are probably guys on here that have done e-fuel that would sell you their bowl for cheap.
on
1 Post
I'm about to replace the fuel pump on my 97 F250. I'm interested in the efuel option. Can anyone give me some details? The dealership wants $1100 bucks to replace the pump. I can do it myself for about $200 or I can go with efuel. If I can do that for $500 or less, then I want to give it a try.
500 is pushing it, probably can be done, but tough. I'm following TJ's thread, about 700 or so doing it this way.
https://www.ford-trucks.com/forums/1...=electric+fuel
Here are some wiring options if you do this.
https://www.ford-trucks.com/forums/1...ec+fuel+wiring
