T98 speedo gear question
Old 10-10-2012, 02:08 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
OK so I'm getting to put the engine and trans in my '59. First I'd like to get close to the right speedo gear/s in it before the big stab. 3.50 rear gears, 29.5" tire height. I know the driven speedo gear is 19 teeth and I'd like to avoid taking the back of the trans apart to count teeth on the drive gear. Is this a question for numbers dummy? Thanks
Old 10-23-2012, 09:54 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Is this a question for numberdummy?
Must be, since no one else has responded in 13 days. I've been away or woulda responded sooner.
1959. Could be a cast iron DRIVEN gear, or a fibre DRIVEN gear riveted onto the end of a steel shaft.
Look closely at the original, it should an ID number stamped on it.
Once I know which DRIVEN gear is has, I can figure out the DRIVE gear.
Old 10-23-2012, 10:13 PM
ibuzzard's Avatar
ibuzzard
ibuzzard is offline
Panties NOT in a Twist
Tumbleweeds been blowing through here lately......
Old 10-24-2012, 08:25 AM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
ND, it is a cast iron gear. I have 2 transmissions to choose from and I'll get you some #'s today.
Old 10-24-2012, 08:43 AM
NumberDummy
19T cast iron DRIVEN gear = Ford part number & stamped: 01T-17271-B / Verify this is the number stamped on your gear.
Old 10-24-2012, 09:25 AM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
Number
O1T-71
8-19
Could be B-19, but I'm guessing the 8 is the # of drive gear teeth?
Old 10-24-2012, 10:05 AM
NumberDummy
01T, cannot be 71, will be 17 (271)-B
Could be just 01T-B.
If 8 was marked on DRIVEN gear, it would have nothing to do with DRIVE gear teeth, because what DRIVE/DRIVEN gears truck has, depends on trans type, rear axle ratio and original bias ply tire sizes.
1964 F100 2WD 3.70-1 4 M/T 7.00-15 tires: B9C-17285-A 7T DRIVE gear / 01T-17271-B 19T DRIVEN gear
1964 F250 2WD 4.56-1 4 M/T 6.50-16 tires: 01T-17285-B 6T DRIVE gear / 01T-17271-B 19T DRIVEN gear.
How many more examples would'ja like? There are pages of like examples for F100/350's, P350/500's, F500/600's and etc etc etc!
Old 10-24-2012, 10:16 AM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
ND I appreciate your help. I went with the bottom #'s beng 8 for drive gear and 19 for driven gear. If that's the case, my 3.5-1 rear gears are perfect for 29.5" tires.
Who stocks gears for these? I've struck out, but it looks like my #'s are AFU.
Old 10-24-2012, 10:54 AM
NumberDummy
There are dozens of 01T-B DRIVEN gears available NOS, I haven't figured out which DRIVE gear will be correct, but all I see are 6 & 7T steel gears.
There are 8T DRIVE gears, but they are nylon. I doubt your truck has a nylon gear unless the tranny's been swapped.
Old 10-24-2012, 02:20 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
ND, sorry for the confusion. Both my trannies are for an F350. I pulled the other driven gear and it reads as follows:
01T-71
E22
The first one is a 19T gear and the one in front of me is a 22.
This is the main reason I don't want to pull the drive gear out. I don't have a socket, impact wrench or compressor that will break the big nut off to pull it out.
Zachthemoo2
10-02-2014 04:42 PM
PetesPonies
06-02-2010 11:04 PM
christians63
02-15-2010 04:09 PM
jas88
06-24-2007 05:42 PM
yellow72f100
11-02-2005 06:52 PM
Quick Reply: T98 speedo gear question
