You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
OK so I'm getting to put the engine and trans in my '59. First I'd like to get close to the right speedo gear/s in it before the big stab. 3.50 rear gears, 29.5" tire height. I know the driven speedo gear is 19 teeth and I'd like to avoid taking the back of the trans apart to count teeth on the drive gear. Is this a question for numbers dummy? Thanks
Is this a question for numberdummy?
Must be, since no one else has responded in 13 days. I've been away or woulda responded sooner.
1959. Could be a cast iron DRIVEN gear, or a fibre DRIVEN gear riveted onto the end of a steel shaft.
Look closely at the original, it should an ID number stamped on it.
Once I know which DRIVEN gear is has, I can figure out the DRIVE gear.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
If 8 was marked on DRIVEN gear, it would have nothing to do with DRIVE gear teeth, because what DRIVE/DRIVEN gears truck has, depends on trans type, rear axle ratio and original bias ply tire sizes.
ND I appreciate your help. I went with the bottom #'s beng 8 for drive gear and 19 for driven gear. If that's the case, my 3.5-1 rear gears are perfect for 29.5" tires.
Who stocks gears for these? I've struck out, but it looks like my #'s are AFU.
ND, sorry for the confusion. Both my trannies are for an F350. I pulled the other driven gear and it reads as follows:
01T-71
E22
The first one is a 19T gear and the one in front of me is a 22.
This is the main reason I don't want to pull the drive gear out. I don't have a socket, impact wrench or compressor that will break the big nut off to pull it out.
