2011 F150 Brakes - Ford Truck Enthusiasts Forums
2011 F150 Brakes
Old 10-10-2012, 02:12 PM
geno87_69's Avatar
geno87_69 geno87_69 is offline
geno87_69 is starting off with a positive reputation.
2011 F150 Brakes
I have a 2011 CC 4x4 ECOBOOST F150. I have 45,000 miles on it and the front brakes started squealing.
Has anyone changed there fronts yet on a 2011? Any suggestions on pads?
Any tricks for this job that I need to be aware of?
Any information, hints, or advice would be greatly appreciated.
Thanks,
Old 10-12-2012, 09:08 AM
juneau76's Avatar
juneau76 juneau76 is offline
juneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud of
I just rolled over 41,000 miles on my 2010 and still have the factory pads/rotors, so I can't offer any advice. I'm a fan of ceramic pads myself, but they tend to be a little pricey compared to the semi-metallics. I also like drilled/slotted rotors, but they have the same issue on price. There are lots of opinions on this topic.
Old 10-12-2012, 10:23 AM
geno87_69's Avatar
Thanks.
I would have expected these to last longer. My F250 brakes went 90,000 miles, and my driving habits have not changed??
Old 10-12-2012, 11:04 AM
oldrifleman oldrifleman is offline
oldrifleman is starting off with a positive reputation.
Quote:
Originally Posted by geno87_69 View Post
Thanks.
WOW, 90K on the 250? that is outstanding, mine lasted about 25K on my 02 F250 and then had issues. I am hopeing my F150 will get 50K before it needs new brakes.
Old 10-12-2012, 11:20 AM
geno87_69's Avatar
Heck they probably will make 50K. I am just getting my ducks in a row...
Old 10-12-2012, 06:41 PM
blueovelboy's Avatar
blueovelboy blueovelboy is offline
blueovelboy has a very good reputation on FTE.blueovelboy has a very good reputation on FTE.blueovelboy has a very good reputation on FTE.blueovelboy has a very good reputation on FTE.
my 2010 had a bad charter at 23800 ford changed them out. ill never let some one use it to tow a utility trailer again!
i would get factory if your not going with brim bro or some other top notch brake up grade!
Old 10-13-2012, 03:22 AM
Jus2shy Jus2shy is offline
Jus2shy has a great reputation on FTE.Jus2shy has a great reputation on FTE.Jus2shy has a great reputation on FTE.Jus2shy has a great reputation on FTE.Jus2shy has a great reputation on FTE.
I personally have had great luck on all my vehicles with ceramic pads. My wife's subaru clocked 88k before the front pads needed changing. The rears could probably have gone to 130k at the rate they were wearing. I believe Ford uses a Ceramic formulation, most manufacturers are going this route to keep dust down since so many people love having shiny rims (myself included).
However, if you're not into racing I must highly recommend sticking with solid vented rotors. Slotted, dimpled or even cross drilled rotors are subject to more cracking stresses because of the thinner/non-existent material on those rotors. You will stop more effectively, but your chances of getting as much life out of far more expensive rotors (especially if you haul at all) is very slim. They're fine for sport cars, but then you're only stopping 3,000 lbs of car. Our trucks weigh on the order of around 6k for most configurations, then add on the payload or whatever you're towing. You're subjecting breaks to longer duration braking events and probably experiencing a higher delta in temperature because of the amount of mass having to be stopped. Besides, with solid face rotors, you can probably machine them and get some decent life out of them with a 2nd set of pads.
Old 10-15-2012, 11:52 AM
shortride's Avatar
shortride shortride is offline
shortride is gaining momentum as a positive member of FTE.shortride is gaining momentum as a positive member of FTE.
Squealing brakes can commonly be contributed to a lot of stop and go traffic and very common when brakes get hot from hard braking. There are pads that are better than OEM brake pads but the brake rotor would very likely need to be turned to remove the glaze removed.
Old 10-16-2012, 09:57 AM
PrinceValium's Avatar
PrinceValium PrinceValium is offline
PrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to all
Some brakes squeal before the pads really need replacing, if there is still pad left on them you can have the rotors turned to resolve it. The rotors can glaze over depending on your braking habbits (do you keep your foot covering the brake a lot? Sme people do and inadvertantly use e brakes much more thathey should) There are also times when a rock or something gets wedged in by the rotor causing a squeal.
Old 10-31-2012, 03:18 PM
geno87_69's Avatar
Thanks for all of the advice. I will check prior to ordering any brake pads.
Old 11-05-2012, 11:17 AM
TA77 TA77 is offline
TA77 is starting off with a positive reputation.
Mine squeek and my mechanical can't find anything wrong.
2011 Front axle seal and bearing fitter66 2007 - 2014 Expedition & Navigator 0 11-29-2016 10:07 AM
Turning Front brake rotors BigDfromTN 2009 - 2014 F150 13 03-29-2016 08:06 PM
Grinding/Rustling Noise - 2011 F150 Limited 2011Limited 2009 - 2014 F150 41 12-04-2014 09:58 AM
2011 Rear Brake Part question. ilmo 2009 - 2014 F150 1 04-15-2012 03:41 PM
BDS 4" lift kit for 2011 F150 jojolimited Offroad & 4x4 0 03-03-2012 07:02 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
