Transmission normal operating temp. How long? - Ford Truck Enthusiasts Forums
Old 10-10-2012, 09:49 AM
hikeril hikeril is offline
hikeril is starting off with a positive reputation.
The temp on the screen shows that the transmission temp normal operation is about 190 degrees no towing. How long should it take to reach this temp? I drove 40 miles at 65 mph before it exceed 180 degrees in air at 45 degrees. Is this normal?
Old 10-10-2012, 02:20 PM
Painted Horse's Avatar
Painted Horse Painted Horse is offline
Painted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud ofPainted Horse has much to be proud of
I think it will depend on how hard you are working the truck. The tranny does cool itself with the secondary coolant system. If you never get the coolant warmed up, what ever heat the tranny is producing will be carried off by the coolant. I suspect on a light work out, the tranny is just going to get to it's minimum temps. As soon as it's thermastat opens, the coolant will carry off any heat that exist.
the secondary coolant systems doesn't circulate through the engine block, It passes throu the CAC, Fuel cooler, EGR cooler and transmission cooler. So it is slower to warm up than the primary coolant. It takes a while for the fuel that passes through the system and returns to the tank to be warm enough on the return trip to actually need cooling. If you are not running the engine at higher combustion temp, the egr isn't as active and requires less cooling and same goes for the tranny. I could see where thatsystem could take a while to come to temp.
Old 10-10-2012, 02:45 PM
The engine was not being worked hard with flat terrain and even 60 mph speeds. It has been like this since the beginning of ownership. The truck is an 2011 F250 with 14,000 miles. I guess I was curious if maybe the thermostat was stuck open if it even has one. I am definitely not an expert on engines. Based on the information shared it does not sound like an issue to be concerned about. Thanks.
Old 10-10-2012, 04:00 PM
mountainhoundf350 mountainhoundf350 is offline
mountainhoundf350 is starting off with a positive reputation.
Glad to see I am not the only one to notice this, mine takes about 25 miles and I am in hilly terrain. Heck the motor is slow to warm also, about 15 miles. My 04 6.0l was at temp in about 7 miles this time of year.
Old 10-10-2012, 06:54 PM
kper05's Avatar
kper05 kper05 is offline
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
The cooling system does a great job on these 6.7L trucks.
For short trips, it's too good (kind of a joke so no one blasts me).
On cold days, it takes over 10 miles to reach 195 EOT.
Transmission Temp. mark224 1999 to 2016 Super Duty 4 12-09-2016 10:29 PM
What are engine operating temps? SoCalAngler 1987 - 1996 F150 & Larger F-Series Trucks 4 07-17-2014 10:37 AM
M5OD TRANS COOLER? zombie_killer 1987 - 1996 F150 & Larger F-Series Trucks 21 06-24-2013 09:41 PM
460 Running Temp? MustangMatt96GT Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 29 01-05-2009 11:21 PM
Normal operating temperature proteks Cooling, Heating, Ventilation & A/C 17 12-14-2004 01:35 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
