inner door metal rattle??
Old 10-10-2012, 06:18 AM
Buck268's Avatar
Buck268
Buck268 is offline
Wondering if anybody lee has run into this. The rear doors of my supervene have an unfortunate rattle. There is a sheet in the inside of the doors (between the skins) which seems to be just loose enough to rattle when I turn my stereo up (dual h/u with Polk 5x7). Now I tried some silicone sealant in the bases to silince the rattle but with the poor access it just didn't work. I do have dynamat around the speakers and its not your typical speaker rattle as you can here it when you close the doors as well.
Any thoughts? Id almost like to try shooting some greatstuff in there but I'm worried that it wouldnt worm so hot kn the best case and would screw up the latching system in the worst case.
Old 10-20-2012, 06:13 AM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
I can't imagine that skin would rattle because it's so thin. My door lock mechanisms used to rattle on my 2000.
Old 10-20-2012, 09:04 PM
lariat97's Avatar
lariat97
lariat97 is offline
Get some sound deadening. Put it on both sides & the outer skin. Seal the door.
officer131
07-06-2016 09:05 PM
v6lightning
07-18-2013 12:12 PM
preppypyro
08-16-2008 09:39 PM
Wakeboarder141
2004 - 2008 F150
10-07-2006 11:39 AM
zman764
1997 - 2003 F150
08-16-2006 11:31 PM
Quick Reply: inner door metal rattle??
