Ghost in my brake system
I'm looking for a little help here. I went out to start my '63 and the battery was dead. I hooked-up the charger and after a few minutes, noticed the brake lights were on. I disconnected the wires from the master cylinder pressure switch which solved the problem.
Ordered a new brake light switch, put it in, and did a test drive. After returning and having parked in the garage for 10 minutes, the brake lights suddenly came on. Must be some kind of residual pressure left in the system.
I have the fruit jar master cylinder and will likely replace it with a dual cylinder MC - although 49.5 years of good service isn't anything to complain about.
My question is what could be causing the switch to suddenly close after sitting for 10 minutes? Could it be a stuck wheel cylinder that suddenly was freed?
Thanks.
Dave
Thanks.
Dave
Thanks. I'll give it a try.
aj3501
12-28-2014 08:30 PM
faype02
07-27-2001 09:49 AM
