2004 F 550
2004 F 550
I have a 2004 F 550 and I was driving and stopped to fuel the truck and it stopped. I tried to start it but it would not start. I went to autozone and bought a new fuel pump. It started but every time I would stop, it would take awhile to start (after couple of seconds of cranking)Then I drove another 600 miles and I stopped at a mc donald and now it's not starting. there is no pressure in the fuel system when i take the key out and check the pressure. What could be the problem? If I put starting fluid, it will start (for one second)
Yes it's a 6.0 diesel. The worst ever made by Ford: 04, 05, 06, 07 . Actually they are international engines. But I replaced the fuel pump and there is no pressure in the system. Takes a lot of cranking to start, and sometimes it just does not start. I took the top filter out and I noticed that the fuel was going backwards inside the supply fuel and not the other line (excess). I thought that was weird.
Bikedude987
05-10-2012 10:21 PM
