2012 F 350 with shudder. need help. - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-09-2012, 07:54 PM
jgust001 jgust001 is offline
jgust001 is starting off with a positive reputation.
I have a 2012 F 350 crew cab eight foot bed with FX4 package. The truck has a shudder when you accelerate from 0 to about 5 mph when I'm towing my 8,000 pound 5th wheel. Once you hit 5 to 10 mph it goes away and everything is smooth. When the truck is empty there's no problem either. I took it to the dealer and they said we have to shim the rear suspension. Does anyone have any suggestions or fixes ?
Old 10-09-2012, 10:39 PM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
The carrier bearing needs to be shimmed. I know this TSB does not list your year of truck, but it is the same cause and effect.
TSB
06-23-4
DRIVE-AWAY SHUDDER OR VIBRATION
Publication Date: November 3, 2006
FORD:
1999-2007 F-Super Duty
This article supersedes TSB 05-17-6 to update the vehicle model years.
ISSUE:
Some 1999-2007 F-Super Duty vehicles may exhibit excessive drive-away shudder or vibration, under moderate to heavy acceleration from a stop. This may be due to driveline angle.
ACTION:
Shim the center carrier bracket downward to correct the condition. Refer to the following Service Procedure.
SERVICE PROCEDURE
When shimming the center carrier bracket, a maximum of three (3) 1/4" shims may be used (EOTZ-4A209-A). When refastening the carrier bracket use bolt (56564-S2). A 7/16 x 14 grade 5 bolt may be substituted providing that it extends at least three (3) threads past the nut. Use Motorcraft® Threadlock 262, and torque bolts to 46 lb-ft (62 N-m).
NOTE: IF THE VEHICLE IS NORMALLY LOADED, ROAD TESTS WILL NEED TO BE PERFORMED WITH THE VEHICLE LOADED.
Before beginning the repair, road test the vehicle to gain a feel for the harshness of the shudder/vibration.
Install one (1) shim, (DO NOT use threadlock on the bolts at this point), re-road test vehicle.
If condition is corrected, apply threadlock and torque bolts as directed above.
If condition is not corrected, re-perform step 2 (to a maximum of three (3) shims) and reevaluate vehicle.
NOTE: IF THE CONDITION IS STILL NOT CORRECTED AFTER INSTALLING A MAXIMUM OF THREE (3) SHIMS, REFER TO WORKSHOP MANUAL SECTION 205-00 FOR FURTHER DIAGNOSTICS.
PART NUMBER PART NAME
EOTZ-4A209-A Shim
56564-S2 Bolt
TA-26 Motorcraft® Threadlock 262
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
OPERATION DESCRIPTION TIME
062304A 1999-2007 F-Super Duty: Road Test To Verify Concern, Install One Shim, And Road Test To Verify Repair (Includes Time To Raise Vehicle And Install Threadlock) (Do Not Use With 4602A, 4602A4F) 1.2 Hrs.
062304B 1999-2007 F-Super Duty: Road Test To Verify Concern, Install One Shim, And Road Test To Verify Repair Condition Still Exists, Install A Second Shim And Road Test (Includes Time To Raise Vehicle And Install Threadlock) (Do Not Use With 4602A, 4602A4F) 1.7 Hrs.
062304C 1999-2007 F-Super Duty: Road Test To Verify Concern, Install One Shim, And Road Test To Verify Repair Condition Still Exists, Install A Second Shim And Road Test Condition Still Exists Install A Third Shim And Road Test (Includes Time To Raise Vehicle And Install Threadlock) (Do Not Use With 4602A, 4602A4F) 2.2 Hrs.
Old 10-10-2012, 10:53 AM
Thank you so much !!! I will let you know what happens.
Old 10-10-2012, 11:21 AM
SteveH-CO SteveH-CO is offline
SteveH-CO has a good reputation on FTE.SteveH-CO has a good reputation on FTE.SteveH-CO has a good reputation on FTE.
A cautionary note on this 'fix'...
This problem occurred with Dodges, too - and it seems that sometimes you can get it shimmed to work nicely in one setting (with trailer) and it will still shudder in another (unloaded). You may find limited success with this, but I wish you the best.
Old 10-10-2012, 03:08 PM
spud57's Avatar
spud57 spud57 is online now
spud57 is gaining momentum as a positive member of FTE.
What is causing the shudder is with the weight if the trailer, the rear of your truck is sagging enough to cause the shudder. Yes, you can correct it so it won't shudder when you are hooked up but you now you now run the risk of having the shudder return when you don't have the trailer hooked up.
I had the same problem but eliminated it with air bags. When I hook up I am at the same level as when I'm not. No more shudder.
S
Old 10-10-2012, 07:40 PM
goin_campin's Avatar
goin_campin goin_campin is offline
goin_campin is starting off with a positive reputation.
I bought and installed the Ford kit and it did fix the shudder with just one shim. Now that I know what the Ford kit is, I would just go and buy a piece of 1/4 by 1.5" flat bar, cut a 4 or 5 piece off and drill the holes yourself. Also, the new bolts that the TSB recomments are actually shorter that the original bolts. My truck is a 2007, so that may not be the case with yours.
Good luck.
Old 10-10-2012, 11:23 PM
redford's Avatar
S
In the case of the TSB, it is the opposite. The drive shaft to pinion angle is what causes the shudder. Lowering the rear suspension would decrease the angle and the shudder. Lowering (shimming) the carrier bearing also decreases the angle and reduces the shudder.
Old 10-13-2012, 05:38 AM
P.Bronner P.Bronner is online now
P.Bronner is gaining momentum as a positive member of FTE.
Go see the dealer. A member on Dieselstop said they just released a completely new driveshaft to fix the problem. By looking at the pictures he posted, the slip yoke has been moved to the rear of the shaft, putting the U-joint further forward and the support bushing has been made of what appears to be a much stiffer rubber compound. He said it fixed the problem.
Old 10-13-2012, 08:05 AM
Thank you, I appreciate your help.
Old 10-13-2012, 08:09 AM
Thank you.
Old 10-13-2012, 08:12 AM
Quote:
Good luck.
Thanks for the good advice
Old 10-13-2012, 08:14 AM
Great advice
Old 10-13-2012, 08:18 AM
Thank you for the great news
Old 10-13-2012, 11:58 AM
To those who are interested, I can tell you from firsthand experience that shimming the center support bearing down on my '11 made the problem WORSE. I solved a vast majority of the shudder by removing the support bearing bracket and sectioning about 5/8" out of it (made it SHORTER) and welded it back together. This reduced the loaded launch shudder by well over 50% and did not induce any unloaded high speed vibrations. Of course now that I've done all my farmer engineering, Ford comes out and addresses the problem.
2015 Ford F350 6.7 Turbo Diesel - Shuddering & Shaking danloc 6.7L Power Stroke Diesel 51 10-14-2016 07:55 PM
Possible Transmission Issue POS Camaro 6.0L Power Stroke Diesel 11 10-13-2015 09:19 PM
6th Gear shudder when maintaining speed. Keeseter CO 6.7L Power Stroke Diesel 12 10-08-2013 10:17 PM
4R70W shuddering issue nicebenz68 Clutch, Transmission, Differential, Axle & Transfer Case 7 04-02-2013 08:25 PM
2010 F150 5.4 6 speed trans shudder joge 2009 - 2014 F150 1 10-15-2012 09:06 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
