P0401 & P0411 error code on 1996 4.9L
Old 10-09-2012, 04:46 PM
HarleyFXDL's Avatar
HarleyFXDL
HarleyFXDL is offline
Exclamation P0401 & P0411 error code on 1996 4.9L
I am getting a P0401 & P0411 code on my 1996 F150 with the 4.9L 6cyl. The engine seems to run fine but wont pass emissions. I haven't taken anything apart yet. I'm thinking it might be a clogged EGR valve. Anyone else have this problem? Any suggestions?
Old 10-09-2012, 05:07 PM
khadma's Avatar
khadma
khadma is offline
Carpenter Local 745
DPFE or air leak, EGR issue. Look in that area.
How does the truck run?
Old 10-09-2012, 07:24 PM
HarleyFXDL's Avatar
HarleyFXDL
Truck runs perfect. If it weren't for the check engine light, I would never had known there was a problem. Did you ever run into this problem before?
Old 10-09-2012, 08:43 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,164 Likes on 919 Posts
P0401 is a code related to the EGR system. P0411 is from the secondary AIR injection system. Two different systems, two different causes. Both are part of the emission system. Either can cause no driveability issues, but they can also trigger a "limp mode" and decrease mileage/performance.
The most common cause of P0401 are the silicone tubes running from the EGR line to the DPFE sensor are aged/cracked.
Potential causes of a P0411 code include:
  • Damaged or missing check valve
  • AIR pump intake port plugged/damaged
  • AIR pump clutch malfunction
  • Holes or damage to exhaust components
Old 10-09-2012, 08:58 PM
HarleyFXDL's Avatar
HarleyFXDL
Tomorrow, I will look at these areas. Thanks RLA & khad, I'll post my findings.
Old 10-10-2012, 03:54 PM
HarleyFXDL's Avatar
HarleyFXDL
I checked the EGR valve, it wasn't clogged and I put vacuum to it and it opened. I looked around and noticed a plastic vacuum hose that was broken, it went to some vacuum tank. I reconnected it and now the truck is running like crap. Hmmmm, this emissions stuff is a real headache. I located the DPFE sensor, how do you check to see if it is working?
Old 10-10-2012, 04:38 PM
rla2005's Avatar
rla2005
Old 10-10-2012, 04:56 PM
HarleyFXDL's Avatar
HarleyFXDL
Thanks RLA, I will try it tomorrow and report back. Great site!
Old 10-12-2012, 10:46 AM
HarleyFXDL's Avatar
HarleyFXDL
Yesterday, I looked over all the plastic vacuum hoses. I noticed one hose, attached to a vacuum tank, that was broken. I pulled the broken half out of the rubber connector and re-inserted the other half. I disconnected the battery to clear the codes. I just came back from a 20 mile drive and no codes, check engine light is out. Amazing how much trouble one small hose will cause. I hosed off all the dirt and grime under the hood and must have soaked the distributer. The truck ran like crap because the wires got wet. Once the wires dried, the truck ran perfect again. Thanks to RLA and Khad for all your help. You guys saved me some $$$$$.
Old 10-13-2012, 08:33 PM
rla2005's Avatar
rla2005
Glad we could help you out!
ESCAPESTER
Escape & Escape Hybrid
10-13-2008 09:31 PM
Clipper
1997 - 2003 F150
06-14-2006 08:34 AM
Navg8r
10-23-2005 10:44 AM
Colin94Supercab4.0
1983 - 2012 Ranger & B-Series
03-02-2004 11:08 PM
daw1264
1997 - 2003 F150
02-07-2002 07:30 PM
Quick Reply: P0401 & P0411 error code on 1996 4.9L
