2002 f250 regular cab 4inch front leaf springs HELP PLEASE
HEY GUYS SO I HAVE A F250 REGULAR CAB 7.3 4X4 I WAS WONDERING IF I JUST PUT A 4INCH LEAF IN THE FRONT WHAT ELSE I WILL NEED TO BUY OR DO TO MAKE IT WORK THANKS
Longer u bolts if the springs dont come with them, adjustable track bar or drop track bar bracket and longer sway bar links (and id recommend new bushings while you are doing it)
4" you must replace the pitman arm, tract bar bracket, sway bar links, longer brake hoses. And a adjustable tract bar isn't necessary but its nice to have to get the front axle perfectly centered. I only have 2" front lift springs and when i flex the truck the front hoses are stretched to the max! I bought a Zone adjustable tract bar and it super beefy and i was able to center the axle after my lift install
Ebay prob ally cheapest and i would suggest a lift kit for a four inch lift, unless you already have a 4" lift and you just want to replace the old springs for new ones.
is that all i need for a 4inch lift in the front and the reason i am doing it like that is because i just want to lift the front up and then block the back would it be the same parts list for a six inch lift in the front to
