WTB: Stock Super Duty Springs - Ford Truck Enthusiasts Forums
WTB - Parts & other Want to buy parts/accessories/tools.
Old 10-09-2012, 02:54 PM
DIYiT's Avatar
DIYiT DIYiT is offline
DIYiT has a good reputation on FTE.DIYiT has a good reputation on FTE.
I'm looking for a set of "T" code front Super Duty springs, and a set of "B" code rear springs.
I'm located in Central Iowa.
Old 04-17-2013, 12:57 PM
rhtrigger rhtrigger is offline
rhtrigger is starting off with a positive reputation.
I have the front and rear springs from a '08 Superduty if that is what you need.
Old 04-17-2013, 02:59 PM
DIYiT's Avatar
I've found a set of front springs, but I am still in need of the rear "B" code leaf springs. Where are you located?
Old 04-18-2013, 10:33 AM
I am in the Kansas City area. How does one know if they are B Code?
Old 04-18-2013, 11:13 AM
DIYiT's Avatar
I believe the spring code is located on the driver's door pillar sticker.
This is one resource I found online for determining your spring pack:
Ford Spring Codes - Shop Ford Leaf Springs by Code | SD Truck Springs
Old 04-18-2013, 03:12 PM
DIYiT's Avatar
After some further research, it looks like the '08+ springs are 8" longer than the '99-07 Super Duties (which are the same length as the '80-97 trucks). I was originally planning on "B" code '99-07 rear springs as they're a direct drop in, but it looks like the '99-07 crowd is beginning to desire the '08+ swap for the better ride that it provides over their springs. Precision Metal Fab makes a bolt on bracket for the '99-07 trucks to accept the '08+ springs. I've contacted the shop to see if the bracket can be made to work on the OBS trucks. If the '08+ springs are better yet than the '99-07, It may be worth looking into what it takes to move my spring hanger forward for a two-fold increase in ride comfort.
leaf springs code? joe98356 1973 - 1979 F-100 & Larger F-Series Trucks 2 10-06-2015 09:03 PM
Little help at the JY? lindstromjd Missouri Chapter 4 06-04-2015 05:42 PM
WTB: E350 dana 70HD srw axle 92-07 Iowa rebar13 WTB - Parts & other 5 02-14-2015 04:46 PM
Headed to Salt Lake City Super Duty Service 6.0L Power Stroke Diesel 16 07-11-2014 09:14 PM
It's Spring FINALLY!!!! Iowa Chat thread fellro86 Iowa Chapter 109 06-22-2014 01:47 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
